S1 wierd missfire/lack of power 6-7psi
Old Sep 21, 2008 | 07:23 PM
original's Avatar
original
Default S1 wierd missfire/lack of power 6-7psi
any help please? S1 escort experiencing weird problems about 6-7 psi, get a weird popping/lack of power/bad misfire from the engine bay.
problem is consistent and always happens. Took car to rolling road and they said it was running massively lean and aborted the run. was told to replace the fuel pump.
have replaced the fuel pump with a new bosch item, have checked the system pressure using a gauge on the cold start line and it is running a constant 6 bar all the time even when the problem occurs.
I have a new fuel filter fitted and the car has a motorsport developments evolution chip/separate board in the silver ecu.
when the problem occurs the rev counter does not flicker/drop, I just back off immediately for fear of killing the engine.
Old Sep 22, 2008 | 07:23 PM
original's Avatar
original
so no-one has any ideas why this would occur? car still running lean. fuel ecu?? pressure regulator??
Old Sep 23, 2008 | 11:57 AM
original's Avatar
original
no-one?
Old Sep 23, 2008 | 01:36 PM
IANS2RST's Avatar
IANS2RST
failed fuel ecu possibly (black box on bulkhead)
Old Sep 26, 2008 | 12:43 PM
original's Avatar
original
ah ok I was thinking this too! So what could fail with it?? are there any known problems with them, other than some pleb sticking it what they think is a power chip off ebay but turns out to be a resistor??lol
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
Iain Mac
Sep 30, 2015 09:39 PM
dojj
Sep 29, 2015 10:32 PM
deathrider666
Sep 28, 2015 06:12 PM
