fan switch i guess
Old Sep 21, 2008 | 10:38 AM
cossieboyIOW's Avatar
cossieboyIOW
Default fan switch i guess
my fan doesnt come on when the car gets hot, the switch is the plug that goes on the thermostat right? i bridge the connections on the switch and the fan starts spinning so does this mean switch is faulty?? also, the temperature gauge in the car said it was probably just under half way, had a look in the header tank and its bubbling like the water is boiling is this normal?? it takes ages for the car to heat up if im driving along, it usually stays in the blue area of the gauge is this too cold??
Old Sep 21, 2008 | 11:00 AM
bloopeta's Avatar
bloopeta
sounds like a dodgy thermostat, like its staying open, that is if it hasnt been removed totally
Old Sep 21, 2008 | 06:43 PM
cossieboyIOW
what ya mean removed totally?? will try another thermostat i guess then thanks matey
Old Sep 21, 2008 | 06:45 PM
sortedsaff's Avatar
sortedsaff
alot of people just remove them . last few rs's ive had havnt had one in.
tony
Old Sep 21, 2008 | 06:46 PM
bloopeta's Avatar
bloopeta
removed totally as in someone has taken out the thermostat at some point and not put a new one in.
Old Sep 21, 2008 | 06:52 PM
RAT8OY's Avatar
RAT8OY
Just sounds like the fan switch is not kicking in. If you are briging the terminals and teh fans are coming on then obviously its either the switch or the cars not getting hot enough, which if left to sit and tick over I doubt very much.
What would worry me most is bubbles in the header tank. If the sytem is under pressure, ie. you havnt realeased the header cap then its either a coolant system leak or the head gasket is fucked (which is technically the same thing).
Old Sep 21, 2008 | 06:57 PM
bloopeta's Avatar
bloopeta
I would imagine from what he said in the 1st post the temp gauge never getting to half way that it is not getting hot enough to kick in the fan.
I think what he means by the header tank bubbling is that the water is getting hot enough to make it bubble, not that the system is pressurising
Old Sep 21, 2008 | 07:41 PM
cossieboyIOW
if left to sit and idle the temp gauge will go right up to the red and the fan will not start, i know that there is a thermostat in there so i guess i need a new switch then...
its just i can start the car from cold and if i drive a few miles without stopping too much it will barely go out of the blue part of the gauge and i never recall it doing that before...
the gauge was about halfway up when i took the cap off the header tank and it was bubbling like when your kettle is just about to flick off and again i dont recall that ever happening before or am i just worrying too much?? lol
i have thought it could be head gasket but im not losing water and the oil in it is normal...
i also for some reason have no boost now lol but its too dark to check why... anyway does anyone know a decent garage as close to portsmouth as possible that i can drive like my grandma to so that i can get it checked and set up or whatever lol, fed up of guessing things now...
Old Sep 21, 2008 | 08:20 PM
Spax's Avatar
Spax
I've got a new switch sumwhere, bought it for my S1 but different connections!
Yours if u want it
Old Sep 23, 2008 | 02:17 PM
cossieboyIOW
ah ive already gone and bought one matey lol just gotta find some time to fit it thanks anyway
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
rsguy
44
Sep 29, 2015 03:29 PM
cossie330
Sep 27, 2015 04:13 PM
IainRS1700T
Sep 25, 2015 06:44 AM
