2.1zvh question
Old Sep 18, 2008 | 07:19 PM
rayner's Avatar
rayner
Default 2.1zvh question
my frst is finally ready to run in, (mot welding pending)
its a 2.1zvh stage2 t3, extensive head work,boost valve, ally rad, cooler, etc...(
standard injectors tho)
running on ofac, from what i imagine hasnt been chipped.
i know the management isnt ideal but will it work, maybe up to 10 psi??
the boost is very low at the moment obiously, but the engine seems to idle and run fine, (ready to run in?) hasnt had a set up as yet.
any info would be appreciated as im not too sure at this stage as
to weather its a recepie for disaster or itll be ok to run in,
main issue is to get it run in for as little expense as poss to make sure the engine is all
ok.i was thinking that it could get set up by a tuner at 6psi as it is. am i wrong?
is it even possible to get set up properly as it is?
thanks
Old Sep 18, 2008 | 07:30 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Standard ecu+injectors will lead to a lean condition due to the increase in displacement.. you're best to get it to a tuner to get it mapped, preferably with the injectors it'll end up having.. OFAC will happily do 1 bar boost (properly) or above that with a bit of hackery. I think MSD is probably the closest person to you for this kind of work.
Old Sep 18, 2008 | 07:33 PM
rst in breaking's Avatar
rst in breaking
id chip at and fit bigger injectors or get it on the rollers and have it set up at very low boost
Old Sep 18, 2008 | 08:11 PM
rayner's Avatar
rayner
THANK YOU VERY MUCH, I HAVE NEEDED THEESE ANSWERS FOR A VERY LONG TIME
NOW.
so maybe safe to get it on rollers and get it set up for 6psi, run it in.
then once runin ok i could think about getting better injectors and management.
as im not totally sure on the best thing to do with the management, any suggestions?
thanks again
Old Sep 18, 2008 | 08:15 PM
rayner's Avatar
rayner
oh, would it be possible to just chip it, and get diferent injecters and
keep original ofac ecu, (which injecters would i use?) and see a decent
amount of boost.
cheers
Old Sep 18, 2008 | 08:17 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
megasquirt is a cheep after market up grade for the magement side of things
Old Sep 18, 2008 | 08:27 PM
rayner's Avatar
rayner
well that was the idea for the car at the start of the project
butmy mate was sorting all that out as im not a clue with
stuff like that, i have a wide band lamda sensor which i baught
and put to one side as i dont see that mate any more. so for me it might
be best if i take the car somewhere for the pros to deal with, especially
when it comes to management.
cheers
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
