leaks
Old Sep 16, 2008 | 05:50 PM
moesin2005's Avatar
moesin2005
Default leaks
used to have puddles in footwell of my s1 had the front end rebuilt completely new battrey tray and anything but its still happening any suggestions
Old Sep 16, 2008 | 05:51 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
door seal,sunroof pipes,windscreen all areas to check!
Old Sep 17, 2008 | 09:50 AM
Marts's Avatar
Marts
I had this.... turned out to be the rear light gasket was letting water through. The water travels under the boot carpet, under the back seat and down to the front of the car. If yours is the same, i'd get it sorted as enough water staying in one place aint good for ford metal
Old Sep 17, 2008 | 11:06 AM
rsfordfan's Avatar
rsfordfan
try the heater mtrix connections aswell they connect behind the dash and leak into the compartment. Can be blamed for a number of leaks I bet!
Old Sep 17, 2008 | 12:01 PM
C534CDB's Avatar
C534CDB
Did you seal round the fuse box when you put it back
Old Sep 17, 2008 | 04:36 PM
moesin2005's Avatar
moesin2005
drivers side is not to bad its the passanger side that is bad and its only just happened with this really bad rain in the last few weeks plus the under dash carpet is wet
Old Sep 17, 2008 | 05:28 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Really does sound like battery tray! Or under the heater motors maybe?
But you say it's all new! Odd.......
Old Sep 17, 2008 | 07:32 PM
moesin2005's Avatar
moesin2005
i think it could be the front screen not to sure
Old Oct 18, 2008 | 08:37 PM
ben skinner's Avatar
ben skinner
I own a money pit!
Thumbs down
i had the same turned out to be the bracket for the wiper motor worth a look
Old Oct 19, 2008 | 07:09 PM
webby80's Avatar
webby80
had this with my last rs after a new battery tray it turned out to be the seam between the inner wing and the bulkhead just infront of the battery tray . water was seeping through once i sealed it up never happened again
Old Oct 19, 2008 | 07:20 PM
studabear's Avatar
studabear
if need be your gonna need to strip the inside of the car to spot where its coming in
Old Oct 22, 2008 | 02:42 PM
s2turbsZVH's Avatar
s2turbsZVH
Will it ever end !!!!!!!
Sure you will find its the heater matrix !!
I had the exact same problem a few years back - went to put car thru car wash and ended up with a bubble bath on the floor - all down to the matrix !!
Old Oct 22, 2008 | 05:37 PM
moesin2005's Avatar
moesin2005
wont be matrix cars been stood for 2 years and it onlyhappens when it rains
Old Oct 22, 2008 | 05:46 PM
Karlos G's Avatar
Karlos G
Balls Deep!
hehehe yeah and why would you have a bubbe bath from a leaking heater matrix? Was there soap and shampoo in with his coolant??
timsrs
Nov 13, 2018 11:48 AM
Fudgey
21
Sep 30, 2015 06:19 PM
wheelwizardrefurbs
Sep 21, 2015 06:42 AM
talon1
Sep 15, 2015 10:27 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
