Post Re Paint - 2K Shopping list. Can any one help.
Old Nov 9, 2004 | 07:17 PM
L33 BYT's Avatar
L33 BYT
Default Post Re Paint - 2K Shopping list. Can any one help.
Alright guys and Girls.
RS is in the garage over winter and im having the engine out to sort out some wiring and engine issues. any way wanna respray the bay.
Will cellulose give a good enough finish - With celluslose will it need laquar. Any tips would be greatly apreciated.
Old Nov 9, 2004 | 08:19 PM
Lee Reynolds's Avatar
Lee Reynolds
You dont lqauer Cellulose. Cellulose is flatted back and then polished to give the best result....not ideal for the engine bays hard to reach places!
Best results use a good 2k acrylic. Thats base coat and laquer. Base coat is apllied then laquer to give a really goo shine. Sometime still needs buffing but not to shine it just to remove particles of dust etc.
See my Engine bay restoration thread for the ultimate shiney experience lol!!!
Old Nov 9, 2004 | 08:25 PM
L33 BYT's Avatar
L33 BYT
Wanted to use 2Pac, Im just Jo public though and cant get hold of it.
Old Nov 9, 2004 | 08:27 PM
L33 BYT's Avatar
L33 BYT
As for your mini resto Lee, Nice work. Looks spot on.
Old Nov 9, 2004 | 10:04 PM
Lee Reynolds
you cant get holf of 2 pac? Are ya sure mate, i got mine from my local autopaint. All paint stockists ermmmm stock it!! LOL. Its the most common way of painting now mate!!! Youll be ok. Make sure ya wear a mask and take regular breathing breaks as it contain very harmfull chemicals such as syanide(spell)
Old Nov 9, 2004 | 10:05 PM
Lee Reynolds
BTW im just joe public too im a brickie not a paint sprayer
Old Nov 10, 2004 | 07:04 AM
Moose 130's Avatar
Moose 130
You used to be able to get isocyanate(sp?) free paint, it'll cost a bit more but from a health point of view its got to be worth it.
Old Nov 10, 2004 | 06:49 PM
L33 BYT's Avatar
L33 BYT
I will try some where else. I went to a paint place in Cambridge and they asked if I owned a body shop. I said no and they said they cannot supply it to me.
I'd rather do it with 2Pac
Old Nov 17, 2004 | 02:55 PM
adamS2RST's Avatar
adamS2RST
Lee, got to Partco in Bury, they will sort you out
Old Nov 17, 2004 | 06:25 PM
L33 BYT's Avatar
L33 BYT
Ideal timing Adam. Having the engine out this weekend!
Where bouts are they never knew there was one
Old Nov 17, 2004 | 09:23 PM
adamS2RST's Avatar
adamS2RST
Lee,
If you come from newmarket A14, get off at westley bury turning, come past the shell garage you come to a set of lights, do a right at them and it is up on that ind estate, follow it round to the left and you will see them on your right....
Old Nov 17, 2004 | 11:17 PM
xr-stu's Avatar
xr-stu
im having a change of plan and redoing the engine bay at the same time, and was going to ask this same question soon myself!
with cellulose, by saying it needs to be polished, is it just a case of a couple of hours with some t-cut, or cutting compound and proper wax and shit?
Old Nov 22, 2004 | 06:18 PM
L33 BYT's Avatar
L33 BYT
UPDATE UPDATE UPDATE UPDATE UPDATE.
My spray guun has finally arrived so will be doing my front panel.
Now want to go the 2Pac route as suggested.
What am I gonna need in the way of paint, thinners and harders.
Any help will be greatly apreciated
Old Nov 22, 2004 | 06:19 PM
sjoyce666's Avatar
sjoyce666
i thought this was for sale
Old Nov 22, 2004 | 06:22 PM
L33 BYT's Avatar
L33 BYT
will be, want it looking spot on however.
Old Nov 22, 2004 | 09:04 PM
S1 JOHN's Avatar
S1 JOHN
i would say you would need 1L of 2k black an 1L 2K hardner make sure you give your engine bay a good keying of with some 320 grade sand paper, then give it a prime with some 2k primer when the primer is dry give it a dust coat of satin black. This will show you any imperfections when you flat it down, use 800s wet and dry sand paper. Then give it a good clean down with a damp cloth. When its bone dry time for paint use a tack rag (sticky cloth) you should be able to get these from paint suppliers, removes any dust. when you buy your paint ask for some mixing cups this will make it easier to mix your paint. you should mix your black 2 parts black to one part hardner. hold gun about six inches away from pannel set your air presure at about 45psi over lap each stroke by about a quarter so you don,t get a dry line. give it one coat leave about 10-15mins then re coat.
JOB DONE HOPE IVE BIN SOME HELP AN JUST HAVENT RABBITED ON.
Old Nov 23, 2004 | 06:16 AM
L33 BYT's Avatar
L33 BYT
Spot on cheers!
martinmilne
Oct 18, 2019 02:18 AM
