Duratec, Omex, Throttle bodies... issues
Old Sep 14, 2008 | 11:00 PM
AdamB's Avatar
AdamB
Default Duratec, Omex, Throttle bodies... issues
I have finally started the duratec in my fiesta
it has a start up map on the ecu
when i try to rev the car it doesn;t like it and will come close to cutting out, anybody have any ideas what i need to do, i thought it should rev on a startup map, or do things need adjusting?
Old Sep 15, 2008 | 05:25 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
The map is most likely a million miles out.
Old Sep 15, 2008 | 05:37 AM
OldDan's Avatar
OldDan
Or maybe cam timing?
Old Sep 15, 2008 | 11:03 PM
AdamB's Avatar
AdamB
engine has never come apart
wont be anything internal
Old May 31, 2009 | 08:02 AM
bronco_z's Avatar
bronco_z
Had same problem. Connectors on flywheel sender was correct according to manual but after switching I got it to rew upp. Still have lots of other problems with the system so if anyone has any good maps I would happily test them. Duratech 1,6 sigma engine.
Old May 31, 2009 | 04:06 PM
Surely omex have a closer map in their library ?, worth asking the they can email it to you to dowload on pc/laptop then onto ecu.
Old May 31, 2009 | 10:59 PM
OldDan's Avatar
OldDan
What is the spec of the engine?
Old Jun 1, 2009 | 05:04 AM
bronco_z's Avatar
bronco_z
What do you mean with spec. English is not my first language so please use basic english
Old Jun 1, 2009 | 06:48 AM
spec is short for SPECIFICATION, ie what is the engine cams, headwork, block etc etc basically what has been done/added to the engine to make it different.
Old Jun 1, 2009 | 06:23 PM
bronco_z's Avatar
bronco_z
1,6 Duratech Sigma from a focus flexifuel-04
Now fitted in a westfiels chassi.
Air temp sender, engine temperature sensor from Omex
Throttle position sensor from BMW (E36 i think)
MAP sensor from Sierra DOHC -93
No other things has been changed in the engine.
mk3ste
Oct 17, 2021 10:09 AM
Mark_
14
Jan 16, 2016 05:27 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Iain Mac
Sep 30, 2015 09:39 PM
SMILER258
Sep 28, 2015 09:04 AM
