sierra xr4i
Old Sep 11, 2008 | 06:40 PM
focus2.0's Avatar
focus2.0
cosworths the way forward
Default sierra xr4i
does the xr5i use a mt75 gear box ?
Old Sep 11, 2008 | 08:40 PM
mick's Avatar
mick
2.8 xr4i uses a type 9 as standard
Old Sep 11, 2008 | 10:22 PM
focus2.0's Avatar
focus2.0
oh right thanks. so the sapphire cossie uses a mt75 ?
sorry im learning.
Old Sep 12, 2008 | 06:24 AM
2wd cossie use T5, type 9 would not be up to the job in a cossie, xr4i/2.8i(capri) ones are slightly different to std type 9's ratio wise I beleive.
Old Sep 12, 2008 | 01:16 PM
focus2.0's Avatar
focus2.0
im looking at doing a cosworth 4x4 conversion. what kind of work is involved, i know its a lot ! but just wondered what is was i would need to change ?
Old Sep 12, 2008 | 01:17 PM
focus2.0's Avatar
focus2.0
i have a mk 2 focus like andrew gallachers one
Old Sep 12, 2008 | 02:27 PM
A lot of work but can be done, and has been done before, probably best to start with crashed 4wd cossie.
Old Sep 14, 2008 | 04:11 PM
focus2.0's Avatar
focus2.0
andrew gallacher does the fabrication work but would he fit the running gear if i supplied it ?
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Fil
Sep 30, 2015 12:08 PM
