frst not boostin
Old Sep 10, 2008 | 09:01 PM
kieran265's Avatar
kieran265
Default frst not boostin
hi i have frst and sometimes wen driving it hard it wont boost.
i bought the car a few months back and it came with superchip, when i put the chip in it will boost again, could it b that the car is set up to run the super chip all the time?
any help would be appreciated
thanks kieran
Old Sep 10, 2008 | 09:05 PM
tooly80's Avatar
tooly80
tooly80
you need to put a switch off the amal valve so you can turn the chip on and off.my mate had to do it to mine.
Old Sep 10, 2008 | 09:09 PM
NATH-RSZT's Avatar
NATH-RSZT
AAAAAAAAAAA????
If a car has a superchip then its ment to run it all the time not now and again when you feel like it.
Mate what spec is your car and what chip is it I'e.
What injectors.
Intercooler
ETC.
EDIT. just read again , YES if your car has a chip and it runs ok with it plugged in THEN leave it in and never unplug it and drive it again or you may kill your engine
Old Sep 10, 2008 | 09:33 PM
kieran265's Avatar
kieran265
what damage may be caused by not using the chip?
is the engine set up for the chip then and also how would i put a switch on it?
its a j plate standard intercooler at mo and think injectors are standard too
thanks kieran
Old Sep 10, 2008 | 09:38 PM
tooly80's Avatar
tooly80
tooly80
[quote=NATH-RSZT;3570970]AAAAAAAAAAA????
What injectors.
Intercooler
ETC.
mine was running then went slugish thn ok then shite again fitted this switch and it runs sound now, its a hamend chip 155 to 195 bhp chip on s1 management.
Old Sep 10, 2008 | 10:09 PM
NATH-RSZT's Avatar
NATH-RSZT
[quote=tooly80;3571069]
Originally Posted by NATH-RSZT
AAAAAAAAAAA????
What injectors.
Intercooler
ETC.
boothy you are running mfi if its s1 setup so its completely different to his problem , 165 and 195 chips are for efi setups so i dont think yours will have one. it will be some other sort of chip.
Kieran if you car runs crap with the chip out, then runs normal with the chip in then you dont have a problam , Leave the chip in and drive it.
Old Sep 10, 2008 | 10:15 PM
tooly80's Avatar
tooly80
tooly80
[quote=NATH-RSZT;3571139]
i dont no ive got all the seriel numbers tha was on it, because mine is rst engine made up of both s1 & s2 in an estate (combi) can i find out wot it is from these numbers.
Old Sep 10, 2008 | 10:57 PM
tooly80's Avatar
tooly80
tooly80
[quote=tooly80;3571163][quote=NATH-RSZT;3571139]
i dont no ive got all the seriel numbers tha was on it, because mine is rst engine made up of both s1 & s2 in an estate (combi) can i find out wot it is from these numbers. its a harman chip but no where to find any info out bout it.
Billy_RS
16
Oct 11, 2025 09:41 PM
gambo08
Fiesta RS1800/RS Turbo
Sep 16, 2015 08:10 PM
bigryrs
Sep 5, 2015 02:57 PM
rsturbo27
Sep 1, 2015 09:54 PM
bigryrs
Aug 28, 2015 05:32 PM
