HELP! setting gear linkage
Old Sep 10, 2008 | 11:06 AM
bloopeta's Avatar
bloopeta
Default HELP! setting gear linkage
Its a S2.
I know to put car in 4th, loosen bolt.
Turn shaft in box clockwise then push all way in. (making sure you dont hit reverse)
Bit I cant get is, use 3.5mm drill bit to lock gear selector.
Where the hell do I put the drill bit???? any pics would be a great help or a detailed discription (in laymans terms LOL)
Old Sep 10, 2008 | 11:20 AM
orionmojo's Avatar
orionmojo
i slackened off the bolt, then selected all gears, inc reverse then put it in neutral and tightened it up again, it was 90%. so i did it again and its 99% now. i didn't know there was a way to "set it" so to speak.
Old Sep 10, 2008 | 11:24 AM
NATH-RSZT's Avatar
NATH-RSZT
never knew this either i have always just pushed it on the thin shaft and done it up. if the selector sits to far forward or back etc then undoo it and slide forward or back etc.
Old Sep 10, 2008 | 11:57 AM
bloopeta's Avatar
bloopeta
yes the above way is the correct way to do it apparently, according to Haynes and Ford
Old Sep 10, 2008 | 01:20 PM
bloopeta's Avatar
bloopeta
found it, its right onthe bottom of the selector housing on underside of car.
Id say more like a 4mm drill needed than a 3.5mm though, it was a bit small, I had to get my lass to lie under the car and hold it in place whilst I tightened nut up at other end
Old Sep 10, 2008 | 01:26 PM
Barry R's Avatar
Barry R
you need to put in in reverse then clamp it read the manual its only 4th if its a 4 speed box
Old Sep 10, 2008 | 02:38 PM
bloopeta's Avatar
bloopeta
not so. that is why there is a purpose made hole to lock it in 4th.
Old Sep 18, 2008 | 04:59 PM
kevnoize's Avatar
kevnoize
RsTurbo crewe ina corna.
I have a 5 speed box whas the difference? and what do i undo?
thanks.
Old Sep 18, 2008 | 06:00 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
You boys are making hard work out of this. I just put the 'box into third (once you get under there and put it in neutral and turn your brain on, it's not that hard to work out where third is), then put the shifter linkage on and tighten it, but still allowing it to be moved. Then jump in the car and move the gearstick to roughly where you think third should be, then tighten the linkage. Try it out, see what it feels like, then tweek from there as required.
Old Sep 18, 2008 | 06:47 PM
bloopeta's Avatar
bloopeta
why bother guessing an tweeking though when ford have put a purpose made hole to lock the gearstick in fourth?????
Old Sep 18, 2008 | 06:49 PM
bloopeta's Avatar
bloopeta
thanks.
there is no diffrence mate, the topic I wrote is for a 5 spedd box, that i what I have also.
What you undo is the bolt on the end of the gear linkage that attatches to the shaft on the gearbox.
look underneeth the car at the gearbox, you cant miss it.
Old Sep 18, 2008 | 06:54 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
Does the shaft not centralise itself when in neutral anyway? It did on my iB5.
Old Sep 18, 2008 | 08:48 PM
kevnoize's Avatar
kevnoize
sorted mine neway.
Old Sep 19, 2008 | 09:29 AM
JesseT's Avatar
JesseT
clockwise and in = 5th gear ; this is what should be used with the locking pin.
Old Sep 19, 2008 | 11:51 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Just fitted a new linkage using the locking pin/alan key in 4th gear and it worked perfectly!!
I have a 5 speed box in case people wanted to know.
Old Sep 19, 2008 | 07:07 PM
bloopeta's Avatar
bloopeta
Thank you mate, worked perfect for me too.
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
3doorcozmess
Sep 7, 2015 01:32 PM
Adam Graham
Sep 6, 2015 06:04 AM
turbowag
Sep 3, 2015 08:07 AM
Cragrat
Sep 2, 2015 08:25 PM
