fiesta rst injectors
MMM very puzzled . have you taken the whole fuel rail out then tried cranking the engine as the injectors wont spurt the fuel out till you try starting it.
Other than that make sure the injector loom is plugged in, try unplugging if its is then plug back together
im gettin sprark. fuel pump is kicking in but injectors arnt working. i bought the ecu and loom off ebay £130 ive got a spare ecu but one of the pins is slightly corroded is there any chane of gettin it repaired.
projects been left for a while i just had a thought after lookin at the wirein diagram could it be the injector relay also were is the injection relay located in the fuse box
DixieTheKid
11
Jun 6, 2020 11:20 AM
