GT28 fitting
Old Sep 8, 2008 | 09:39 PM
InFlammen's Avatar
InFlammen
Default GT28 fitting
What do I need to fit a GT28 turbo on my 3dr Cosworth? What kind of exhaust manifold, downpipe, ex. housing, waste gate, hoses... ? Would I need to remap the ECU?
Old Sep 8, 2008 | 09:42 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
You need to remap whenever you change the turbo.. (on a speed density system).
Old Sep 9, 2008 | 02:22 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
GT28s are internal gate unless you get an odd one intended for some kind of OE application, so no need for a seperate wastegate.
They T2 flange normally, but some companies will supply T3 flanged ones, meaning you can use std manifold.
modded standard downpipe due to the 5 bolt turbine flange, its more like an RST one. best bet is prob buy one for a 200SX or similar, then cut the end bit off and weld to the cossie downpipe.
your normal hoses should be fine.
and deffo a remap.
Old Sep 11, 2008 | 10:25 PM
InFlammen's Avatar
InFlammen
No more info?
Old Sep 12, 2008 | 06:34 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
All your questions have been answered?
Kyle Langford
27
Aug 5, 2019 07:54 PM
ekjim
Aug 27, 2015 05:20 PM
IAN RS2k
Aug 18, 2015 07:51 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
