Cosworth Fuel Pressure
Old Sep 7, 2008 | 09:54 AM
ickey818's Avatar
ickey818
Default Cosworth Fuel Pressure
What's the best way to check the fuel pressure on a Cosworth?
Should I remove the fuel feed pipe to the fuel rail and fit the gauage here or is there a better place to tap into the fuel line?
Have tried to remove the fuel pipe from the rail but it's really tight, do you have to cut the pipe off or is there a special tool for removing it?
Thanks
Old Sep 7, 2008 | 11:56 AM
cozmeister's Avatar
cozmeister
More boost Igor!
If it's a 2wd fuel rail with the small hose between the regulator and the rail, fit the gauge between the regulator and the rail
Make sure you depressurise it first though
Old Sep 7, 2008 | 02:12 PM
ickey818's Avatar
ickey818
It's a 4wd Cosworth so no hose between the regulator and the fuel rail, but thanks for the reply.
Think I'll have to remove the main feed pipe to the rail and measure the pressure there.
Prickly_buzz
Aug 25, 2015 11:33 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Bailes1992
Aug 16, 2015 07:14 PM
Aug 14, 2015 07:29 AM
Zoggon
Aug 10, 2015 10:39 AM
