building an engine HELP!!!!!
Old Sep 6, 2008 | 08:16 PM
Smartdj.'s Avatar
Smartdj.
Default building an engine HELP!!!!!
right im going to put my new engine together tomoz and have a couple of questios to ask....iv never done this before...firstly its a series two engine(cvh1900)...with aaslight head work .im ot sure about cam or any thing.....iv cleaned everything and i mean everything...now when i atach the water pump and thermastat housing to the block do i need to use any sealer aswell as the gaskets.....also should i use sealer on the inlet manifold aswell....i have to flywheels one is thicker that the other by about 1-2mm roughly..i think one is a series one and ones of a s2...does it matter which i use....?....(i have new flywheel bolts)i thats all i can think off at the moment but im sure ill think of more in about 2mins lol ...thanks guys couldnt do it without u
Old Sep 6, 2008 | 08:41 PM
costina's Avatar
costina
Live long and prosper!!
No sealer for both and fly would not really make a difference imo
Paul
Old Sep 6, 2008 | 08:46 PM
sm's Avatar
sm
flywheel depends on size of clutch ur fitting a s1 flywheel is 200mm so needs a 200mm clutch a s2 flywheel is 220mm so needs a 220mm clutch, the s2 one is the best to fit as its biggest also before fitting get the flywheel skimmed as if u dont ur nice new clutch could only last a few 100 miles
Smartdj.'s Avatar
Smartdj.
both the flywheels look the same to me so...ill just leave the one thats on there...its thicker so maybe ill get more tq cause its heavier..lol
Old Sep 6, 2008 | 08:53 PM
Smartdj.'s Avatar
Smartdj.
ok the flywheel that on it is to small for my clutch...i take it the s2 one is better because of the size
JoeyBoyden
Jan 4, 2024 02:36 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
Marcus L
Aug 29, 2015 02:18 PM
Ben26
Aug 27, 2015 08:56 PM
Sultzi
12
Aug 16, 2015 01:08 PM
