Fuel pump question - power needed for Greys?
Old Feb 11, 2004 | 01:22 AM
Default Fuel pump question - power needed for Greys?
Is a 100 psi fuel pump okay for running geys, 3 bar, 26 psi, etc? I don't know the flow rate, just the pressure number.
Cheers!
Old Feb 11, 2004 | 01:25 PM
Stu @ M Developments's Avatar
PassionFords Creator
Im afraid the pressure is irrelevent as that will be dropped down to the regulated pressure at teh fuel rail.
You need to ensure it can flow the required volume for the horsepower you intend to run.
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
kosienutter
31
Aug 22, 2015 09:55 AM
col93saphcos
Aug 7, 2015 03:21 PM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
