zvh what turbo?
Old Sep 6, 2008 | 10:02 AM
.Big Dan.'s Avatar
.Big Dan.
Default zvh what turbo?
just bought my first erst a nice black s2 (pic in other post) and me not knowing much about them a mechanic friend tells me it has a zvh conversion (dipstick at the front) done and what i was wanting to know was
1)can i put a cosworth t34 (think thats it) on it
2)how do i tell if its a 1.8 or a 2.0
3)what cambelt do they use cvh or ?
i did try the search function but could`nt find what i was looking for.
thanks in advance
Old Sep 6, 2008 | 10:39 PM
.Big Dan.'s Avatar
.Big Dan.
anyone?
Old Sep 6, 2008 | 10:57 PM
Smartdj.'s Avatar
Smartdj.
sorry m8 cant help but i bet i goes like fuck...good luck with it
Old Sep 6, 2008 | 11:01 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
The engine size is cast into the front of the block in big letters (most likely behind your turbo)..
Yes, you can put a T34 on it.. you can put any turbo you like on it!
Old Sep 6, 2008 | 11:04 PM
Badman38's Avatar
Badman38
1)can i put a cosworth t34 (think thats it) on it.......... yeah no problems there go with the 0.48 exhaust, i run a 0.63 its a bit too laggy.
2)how do i tell if its a 1.8 or a 2.0......... the 2.0L has 2.0 on the side of the block.
3)what cambelt do they use cvh or ?........... use the standard cvh cambelt
thanks in advance
thanks
sean
Old Sep 6, 2008 | 11:07 PM
mikey_clough's Avatar
mikey_clough
as for the cambelt, cvh belt tensioner will fit, i think you need a plate for the tensioner though? go on burtonpower.com and they will have everything you need.
Old Sep 7, 2008 | 12:06 AM
©hatter Box's Avatar
©hatter Box
what the spec of the zvh.is it still on efi or mfi?
Old Sep 7, 2008 | 02:42 PM
.Big Dan.'s Avatar
.Big Dan.
thanks for the info guy`s as for the spec all i have paperwork for is power engineering cam and adjustable pulley some head work and stage 1 t3 ? it does`nt say efi on the inlet so i presume its mfi.
cheers.
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
