zetec black top cambelt issue - pics added
Old Sep 5, 2008 | 07:06 PM
xrsi's Avatar
xrsi
Default zetec black top cambelt issue - pics added
have just timed up my zetec tubo black top and the cambelt is rubbing on the engine metal part of the cambelt cover (the bit that is the actual engine mount section) where there is a ridge on the inside.
has anyone ese come accross this?
the actual part that is rubbing is the toothed side of the belt not the flat side, and its a brand new gates power grip kit with new tensioners and idler....
Old Sep 5, 2008 | 07:32 PM
crazycage's Avatar
crazycage
have put the spacer on the crank then the bottom pulley ??
Old Sep 5, 2008 | 07:41 PM
xrsi's Avatar
xrsi
yep the shim is on the crank and then the toothed pulley.
its not that its to far into the block its too far across.
if you look at the side of the block where it loops around the idler, just below the idler where it is at its closest to the belt where it runs down from the tensoner it rubs on the part of the cover mount effort that is there to split it in half so each belt has a run to go through so to speak....
Old Sep 8, 2008 | 06:55 PM
xrsi's Avatar
xrsi
anyone????
Old Sep 8, 2008 | 07:22 PM
sexr3i's Avatar
sexr3i
isn't it
tensioner or idler's gotta be on backwards/upside down/wrong some other way
Old Sep 8, 2008 | 07:23 PM
rst in breaking's Avatar
rst in breaking
not got any photos to help identify the problem?
Old Sep 8, 2008 | 07:29 PM
xrsi's Avatar
xrsi
nope they only go one way as the idler is round with a perfectly central bolt and the idler has a location lug to fit into the cam belt cover back plate.
and its on the idler side anyways not the tensioner side which as its an idler can not adjust.
rst - n sorry as you can only see where and how it rubs when its all in position and can get a camera there to get a tidy pic.... will try and get pcis of everything in pieces tho if that helps...
Old Sep 9, 2008 | 03:22 PM
spookie's Avatar
spookie
Talking
angle grinder.. (Joking)
Old Sep 9, 2008 | 06:08 PM
xrsi's Avatar
xrsi
you may joke but that was my initial thought if no one had come across the problem!
have got some pics so will try and get them up loaded now....
Old Sep 9, 2008 | 06:34 PM
xrsi's Avatar
xrsi
right here are the pics as promised!
here is the layout of the belt on the blacktop complete with the tensioner on the left and idler on right
close up of idler
rear section of single engine mount includidng the offending potrusion (bit that travels vertically up the middle deviding the centre chamber into two)
mount fitted to engine, can just make out the belt touching the potrusion in the mount.
Any ideas?
Old Sep 9, 2008 | 06:38 PM
djcossie's Avatar
djcossie
close up of idler
Any ideas?
mk1 and mk2 black top mix as it got the idler near the crank pulley
Old Sep 9, 2008 | 06:42 PM
xrsi's Avatar
xrsi
sorry not following.....
Old Sep 9, 2008 | 06:44 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
have you checked the size of the pulleys against the originals?
Old Sep 9, 2008 | 06:46 PM
djcossie's Avatar
djcossie
they is 2 black top zetecs mk1 and mk2
they have diff cam belt set up and cam covers/mounts
Old Sep 9, 2008 | 08:15 PM
xrsi's Avatar
xrsi
DJ cossie - yes there are 2 different zetecs - one is a sliver top and one a black top!
all the black tops have the same cambelt and pulley layout, you are thinking of the silver top having the idler by the crank.
MD cos - i would of if it came with any pulleys.... but unfortunatly it didnt so couldnt check against origional
have just noticed that the timing is slightly out on the 2nd pic tho so will have to check that again tomorrow but that wouldnt cause the rubbing
Old Sep 9, 2008 | 08:55 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
cant you just grind down the bit thats touching the belt? i dont think it would weaken it to any extent.
Old Sep 9, 2008 | 09:01 PM
Turbo Zetec
Engine Machinist
i'll measure mine tomorrow if thats any help?
Old Sep 9, 2008 | 09:06 PM
xrsi's Avatar
xrsi
md - yeah that would be a great help mate if you could.
lloyd, if all else fails then yes i can but i would like to get to the bottom of the cause ratehr than just curing the symptoms as the cam belt is a critical part of the build i dont want any chance of it failing cos something is wrong!
Old Sep 10, 2008 | 05:04 PM
Turbo Zetec
Engine Machinist
the tensioner on the one i've just measured is 60.1mm and the idler was 60mm. It was from a mk2 mondeo, one of the earliest blacktops. Hope that helps
Old Sep 10, 2008 | 05:22 PM
djcossie's Avatar
djcossie
Smile
*edited by webteam - no need for remarks like that*
Old Sep 10, 2008 | 05:26 PM
Lloyd's Avatar
Lloyd
Originally Posted by djcossie
Edited by webteam
thats a bit harsh.
Old Sep 10, 2008 | 05:30 PM
ballin's Avatar
ballin
Edited by webteam
chill out you little pecker
Old Sep 10, 2008 | 05:48 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
Edited by webteam
In English?
Old Sep 10, 2008 | 06:42 PM
SiZT's Avatar
SiZT
and the worst thing is he's right As far as I know there is Series 1 (Silvertop) Series 2 (blacktop without protruding writing from rocker cover), Series 3 (Blacktop with protruding writing from rocker cover) & ST170. I didn't really know the differences between them before now tbh, but it might be worth going into your local motor factors and investigating don't just take my word for it, because as I said, I'm unsure
Old Sep 10, 2008 | 09:00 PM
djcossie's Avatar
djcossie
Default sorry mate
had a hard day at work this is the first thing i looked at when i got home
Old Sep 10, 2008 | 09:28 PM
Adrian's Avatar
Adrian
Still no excuse though. I have had a bad day at work, dont speak to people like that though.
Old Sep 11, 2008 | 07:35 PM
xrsi's Avatar
xrsi
awww i missed it what he say?? lol
Sizt - according to the ford tis and microcat the belts and tensioners are identical on al the blacktops (not including the st170!), there are different covers but the setups are identical according to my info i have here
md- cheers for that will go and have a play with it over the weekend, ive blocked the engine in behine the car and aload of the stufff out of my workshop as im laying the floor in there to make it level over the weekend!
JoeyBoyden
Jan 4, 2024 02:36 PM
Porplus12
Sep 10, 2015 07:20 PM
ekjim
Aug 17, 2015 08:57 PM
gingerturbo
Aug 11, 2015 09:44 PM
