smoke from the breather system
Old Sep 2, 2008 | 08:38 PM
pocket_rocket's Avatar
pocket_rocket
Default smoke from the breather system
As you may have seen from previous threads I've just put a new bottom end in and have had serious oil leak problems which we thought was the breather system (brought a new uprated one) but later found it wasn't that!!!
So oil leak fixed but now have excessive smoke coming out of the small fillter on the breather system, have been told you could expect a small amount of smoke but this is alot.....
Any ideas
Old Sep 2, 2008 | 09:54 PM
Smartdj.'s Avatar
Smartdj.
somthing blocked maybe...
Old Sep 2, 2008 | 11:18 PM
Red16's Avatar
Red16
piston rings worn, this would give you smoke from the breather aswell as exhaust, was the bottom end 2nd hand?
Old Sep 3, 2008 | 06:48 PM
pocket_rocket
yeah it was, my mate had it before me so I know it was in gd nick
Old Sep 6, 2008 | 01:21 PM
pocket_rocket
any body ealse got any ideas???
Old Sep 15, 2008 | 06:50 PM
pocket_rocket
Ok so no more ideas....next question is it going to harm the engine if I drive it hard with this smoke???
Old Sep 18, 2008 | 06:07 PM
pocket_rocket
Old Sep 19, 2008 | 09:42 AM
NATH-RSZT's Avatar
NATH-RSZT
have you got the vacume plumbed into your breather system , also are you sure the crank case breather tube is clear as i've seen so many blocked solid
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
