ignition lock
you need the key in the ignition. remove the top and bottom halves of the plastic covers in front of the steering wheel. look at the bottom part of the ignition barrel , there is a cutout where you can stick a flat screwdriver in. i think the key must be in the on position when you push with the flat screwdriver , it should simply slide out
remove the 2 halves of the steering column shrouds, turn your key to position 1, and on top of the section the barrel sits in is a little hole, put a pointed object in to the hole and push this down and pull on the key and the barrel should slide out.
rsguy
44
Sep 29, 2015 03:29 PM
