anyone pulled of an st sump?
Old Aug 29, 2008 | 06:51 AM
dojj's Avatar
dojj
Resident Wrestling Legend
Default anyone pulled of an st sump?
from the 5 pot?
need to know which side the pick up pipe is, i think it's at the timing end of the engine but not too sure
Old Sep 9, 2008 | 03:51 PM
dojj's Avatar
dojj
need to make the st rwd, but all the sump gubbins are at the front so perhaps it's not a case of putting the engine in as on the cross member
at the moment though, practically there is no where to put the turbo side engien mount as there are no holes there at all, so it looks like i'll hve to use 4 engine moutns on the engine instead
Old Sep 9, 2008 | 03:53 PM
dojj's Avatar
dojj
also, there is no power steering pump
and the alternator is driven by the air con pump
so lots of problems i can forsee happening there when the ac pump siezes up and fucks the alternator
although i'm going to try and source another alternator, or at least try and see if i can get the standard sierra one to bolt up and line up in place
Old Sep 9, 2008 | 07:40 PM
Thefuturesbright's Avatar
Thefuturesbright
JAFSPORT
Your making an ST RWD????
Old Sep 9, 2008 | 07:54 PM
dojj's Avatar
dojj
yup, rwd is the future, i've seen it from loads of years ago, apparently cars handle better too
but nothing looks like making it rwd
i suppose i'll just have to bite the bullet and remove the sump and see what happens
Old Sep 10, 2008 | 05:58 AM
dojj's Avatar
dojj
when it's in the engine bay i'll take some pics and you can all say "wow!!!"
but that'll probably have to wait till the inlaws bugger off again
Old Sep 10, 2008 | 04:25 PM
Thefuturesbright
JAFSPORT
What car you putting it into Dojj??
Ive got someone in volvo going to find out about the pick up pipe for you matey.
Old Sep 10, 2008 | 05:18 PM
dojj's Avatar
dojj
thank you kind sir
it's going to go into a sierra of course
but if i can find a free mondeo then i may decide to put it into there instead as it will all jus tbolt up fairly easily, but where's the challenge in that
if i get a few days free it'll be in the engine bay once the sierra is in bits (the sierra is still hwole and almost running so that's an engine out in the front garden job too)
plus it won't stop fucking raining
Old Sep 10, 2008 | 10:59 PM
Thefuturesbright
JAFSPORT
Cool, cool, love it dojj, lol. I was under the st the other day and it already has the brackets and tunnel for the haldex system, lol.
Old Sep 11, 2008 | 07:15 AM
dojj's Avatar
dojj
i was surprised to see how compact the gearbox is, it's only about 14 inches wide
plus the fact that the sump seems to sit fairly low in comparison to where the crank is
the only downside i've got is that the oil collector sits right at the front of the sump which means i'll have to do some fabricating to see what i can do to relocate it
also, does the st have electric power steering? i've found the remenants of the pipes but no pump or belt to be driven off of
also, i'm going to change the timign belt, any ideas of how to set the timing up?
Old Sep 11, 2008 | 03:30 PM
Thefuturesbright
JAFSPORT
I know the timing belt requires specialist tools so i got told last night, it has to come off supposedly to remove the engine mounts, lol.
The sterring is a rack and pinion, ratio 14.8, power assist 60,5 mm/rev, lock to lock 2.38 revs.
Theres an st sump on ebay at the moment which clearly shows the insides if thats any help to ya.
Old Sep 11, 2008 | 04:06 PM
dojj's Avatar
dojj
theres a dirty great engine mount in the way of the timing belt and it attaches with some big bolts into the head casting, so that deffo needs to come off
what i was more alarmed baout is that you've got to take th timeing cover off to change the aux belts, not something i'd like to want to do in a hurry
shall check ebay forwith
Old Sep 11, 2008 | 04:16 PM
dojj's Avatar
dojj
can't seem to find the link mate
timsrs
Nov 13, 2018 11:48 AM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
Iain Mac
Sep 30, 2015 09:39 PM
youngben
Sep 27, 2015 09:37 PM
