Woooo It Works!!!!!!!
Old Aug 26, 2008 | 06:36 PM
kevnoize's Avatar
kevnoize
RsTurbo crewe ina corna.
Default Woooo It Works!!!!!!!
but its smoking like a mother fucker lots of blue / white smoke. . and also seems like the buggers over heating too but not loosing no water? and temp gauge hasn't moved off the bottom. im actualy not to mitherd aslong as it works now!!! it wouldn't work after it started last time. but now its firing up everytime
Old Aug 26, 2008 | 10:02 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Headgasket! Temp gauge not moving.... either not connected or there is NO water lol!
But well done!! Keep at it mate!!
Old Aug 27, 2008 | 09:17 AM
kevnoize's Avatar
kevnoize
theres water in checked that before starting it up. i asked the lad i got it off bout head gasket he said its all new from the build? all genuin ford parts aswel. got put new starter motor / alternator on today.
Old Aug 27, 2008 | 12:44 PM
kevnoize's Avatar
kevnoize
Put some new plugs in. new alternator in as bat light was on all the time.
(thats solved that problem).. fired up sweet bit smokey but no where near as bad as yesterday. seems to be ideling ok now but when you touch the throttle it dies out abit then go's back to normal unless you press it very gently?. i love rs turbo's there so unpredictable !!
well il put the side skirts back on and stuff now then.
Old Aug 27, 2008 | 03:29 PM
tobyjug_1988's Avatar
tobyjug_1988
could be running a bit rich mate, what colour smoke is coming out?
JK12
33
Apr 26, 2021 12:09 PM
Rstar_man
143
Jul 20, 2020 11:16 PM
