Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
1.7 puma engine tuning
Old Aug 26, 2008 | 05:28 PM
Tank Mike's Avatar
Tank Mike
Default 1.7 puma engine tuning
anything that stands out? im cosidering camming it ect. just wondered what others have done and what gains they got.
Old Aug 29, 2008 | 04:34 AM
stevecossy's Avatar
stevecossy
Hi cams and a cone filter and good exhaust also a chip should see some decent gains,
Try puma speed to see whats avail.
Old Aug 29, 2008 | 10:36 AM
Dal_'s Avatar
Dal_
Cone filter just makes it louder IMO and from others I've spoken to with it say the same (if they're being honest). Use the existing airbox with a flat panel filter, but re-route the air feed to the front port and pipe it up behind the lower grill. (as the FRP does)
A milltek manifold / sports cat / cat back will give you about 8-10 bhp, a remap (from pumaspeed to FRP spec) will give you 8bhp. Cams about 7 and the FRP inlet about 8 (making the difference from 123 standard to 153 on an FRP)
I've got the Milltek and FRP remap and it makes the engine a bit more responsive as well as getting rid of the 'bog down' traction control (it's not really, just a way of protecting the IB5 gearbox on take off) cobblers as std. Whilst their at it, get them to map it for super unleaded - that helps too
You could go down the turbo or NoS route, but that's only if you've deep pockets to do it properly.
SmudgerByName
52
Jul 28, 2016 06:14 PM
Jman-pat
Ford Focus Diesel
Nov 8, 2015 11:06 AM
Ben26
Sep 1, 2015 06:29 AM
Ben26
Aug 27, 2015 08:56 PM
Ben26
Aug 11, 2015 04:19 PM
