4wd gearbox, b&m quickshift,avo coilovers
Old Aug 25, 2008 | 12:55 AM
xr4x4rs's Avatar
xr4x4rs
Default 4wd gearbox, b&m quickshift,avo coilovers
ok got these parts that imnot going use anymore, all have come from my car and in good working order
4wd gearbox, ran on silkoliene fully synthetic oil, no whines or crunches
has been modded to run reyland hydraulic conversion but still use cable aswell, as i need the hydraulic set p still, though i may sell, but i need to sort this part out first
has a new recon front prop that has had both ujs replaced and balanced up
£350
avo coilovers
need a clean, they dont leak, springs were re powdercaoted black, one of the rear adjusters has stopped working, and the spring platform is tight to turn, the rear platforms grub screws have been replaced with bolts as the plastic screws were naff
£250
b&m quickshift, in 4wd cradle with polybushes in, the gear changes were perfect and nice and tight, none of this hitting your hand off the handbrake lever like my old one lol, has covered 4k miles does have a few marks on it
£170
4wd rear uprated propshaft, its twice the size in diameter as a std one id say, mor elike a transit one where my propshft bloke made it for me when it had a new bearing fitted, comes with front part with doughnut which has 3 cracks in it, but never caused me any problems £100
another prop doughnut, im sure it has non or only 1 crack in it but will double check, £40
4wd cossie front calipers with black diamond discs and pads, covered 4k,no warping on the dscs and did there job calipers were reconned by big red 4k ago, and ive painted them silver as the road salt took the zinc off them £250 this is quarter what i paid for the complete set up, incs braided brake lines for fronts
4wd rear calipers, again same as teh front, black diamond grroved and rilled discs and pads, 4k miles, refurbed by big red again, in painted silver and braided lines, handbrake works perfectly
£200
4wd escort carbon heatshield, has done 2k, has holes in th ebakc for lambda and egt probe, bit you carnt see these when there fitted, has a mark on top where stut brace was rubbing on it
£160 cost me £250
need to get these gone asap as there taking up too much space in my garage and i need the funds to put towards a new car ive got my eye on
thanks
any questions please ask, can get pics if needed
also collection only, but will post brakes, cradle and doughnut, prop,gearbox and coilovers id like collection on or you send a courier
Old Aug 25, 2008 | 01:29 PM
xr4x4rs's Avatar
xr4x4rs
updated with some pics
open to offers aswell
Old Aug 25, 2008 | 06:01 PM
xr4x4rs's Avatar
xr4x4rs
now on ebay
Old Sep 12, 2008 | 08:43 AM
booner999's Avatar
booner999
Did you sell the gearbox?
Old Sep 12, 2008 | 11:17 AM
xr4x4rs's Avatar
xr4x4rs
yes
Old Sep 17, 2008 | 04:21 AM
NEIL A's Avatar
NEIL A
Do you still have the B&M shifter ?
chowfornow
14
Jan 5, 2019 09:01 PM
mk1turboestate
Dec 2, 2015 08:31 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
