Itunes Trouble
Old Aug 21, 2008 | 10:10 PM
Brian's Avatar
Brian
Default Itunes Trouble
Is there another software that i could use other than itunes for loading music on to my ipod??
I have tried loading itunes onto my external hard drive but it keeps adding files to my C drive aswell and then when i add music it goes to the C drive aswell so i am running out of space
or is there some setting to stop the files going on to my C drive
Thanks Brian
Old Aug 21, 2008 | 10:18 PM
Thrush's Avatar
Thrush
Irritating c........
There are LOADS....
Windows Media Player (3rd party plugin needed - search MGTEK DOPISP on google)
Songbird
Sharepod
Yamipod
Floola
Or just search ITUNES ALTERNATIVE on google
Old Aug 21, 2008 | 10:47 PM
Billabong's Avatar
Billabong
You can change the default location for your music files to the external drive. ITunes is best left on the C: drive.
Old Aug 22, 2008 | 07:19 AM
Brian's Avatar
Brian
There are LOADS....
Songbird
Sharepod
Yamipod
Floola
Thanks mate will have a look
Do you know how i can change it i can download itunes onto the external hard drive but when i start adding music it also goes to the C drive
Brian
Old Aug 22, 2008 | 09:18 AM
Billabong's Avatar
Billabong
In iTunes, select from the menu:
EDIT>Preferences
Then click the Advanced Tab, at the top CHANGE the iTunes Music Folder Location.
Old Aug 22, 2008 | 09:59 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
vpod is really good imho and takes up little resources on windows
Old Aug 22, 2008 | 10:21 AM
saffsta's Avatar
saffsta
Brian
you dont neccessarily have to run itunes on your external just because your music is stored there, it will still run ok regardless once you have selected the right file path as mentioned above
Old Aug 28, 2008 | 06:09 PM
Brian's Avatar
Brian
I changed the iTunes Music Folder Location but it is still buts the files on to my C drive and its taking up to much space
I dont wont anything to do with itunes on my C drive is this possible
Brian
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 11:21 AM
fordjames
Ford Focus Diesel
Sep 3, 2015 10:20 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
