Vista home SP1 remote desktop
A bit geeky, but thought it might help someone...
Remote destop is usually only available with more expensive Vista.
Here is a hack that works for those in the cheap seats, even if you have SP1
HTH
http://www.unet.fi/fransblog/2007/08...-home-premium/
HTH
Bet Maria plans to remote desktop into the PC at home and use the internet connection there to by pass the work filtering issue you have, good plan
Its also worth remembering that some terminal services downloads posted around the net for this 'tweak' are from earlier and unpatched versions of Windows which bring the exploit documented in security bulletin MS05-041 to Vista.
Don't see why people don't simply use a free alternative which will feature security updates such as :
https://secure.logmein.com/home.asp?lang=uk
or Real VNC Free Edition
http://www.realvnc.com/products/free/4.1/index.html
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
