zetec turbo piston and rod choice.
What piston and rods do people use in a full silver top zetec turbo and what compression do they come out at? I want roughly about 7.5:1 but all the ones i have looked at are much higher than this at 8.5:1 and 9.1:1.
i run je pistons and eagle rods @9.7.1 so i wouldnt say 8.5.1 is high ,what sort of power do you want??
Why would I want to know that? So I know which pistons you're using? Going by the further information you have supplied, I will assumt they are the 'low comp' pistons JE do but on the ST170 head it ends up high! Thanks!
i had some forged xe pistons and just done a compression check. they came out at 9.2:1 which is to high for what i want. How do people get there compresstion down?
silver top rods ( will be using same size eagle). I think i have done the calculations correct.
86mm bore
88 mm stroke
48 cc head chambers
piston to deck 2.5 mm
head gasket wrc 1.3 mm
86mm bore
88 mm stroke
48 cc head chambers
So hang on, you didn't do a compression CHECK - you just calculated it? You need to measure it.
The XE pistons have a slight dish in them.... and they sit more like 3mm down the hole.
I havent bought pistons of rods yet. Im getting information together so i can build. I already had the pistons and just wanted to do a compression test to see if they were any good. sorry if this was confusing.
I have just measured the dish and its 2cc. So if your correct with the 3mm deck to piston hight then the compression is 8.6:1.
http://www.johnmaherracing.co.uk/enginecalc.htm
