efi ported head
Old Aug 14, 2008 | 08:11 AM
project rs's Avatar
project rs
Default efi ported head
am about to go efi and up the power at the same time and wondered who in your own opinion does the best up-rated ported and polished head and any prices if known. i've heard good things about cylinder head developements/norris heads and does it need bigger valves as seems to be a bit of debate on valve sizes and compound they made of, thought i'd see what you all got to say on matter (it's efi head by the way)
Old Aug 14, 2008 | 10:37 AM
picky775's Avatar
picky775
Thought you would do it yourself with ya dremel
Old Aug 23, 2008 | 02:07 AM
rsvmad1's Avatar
rsvmad1
ive just took my head of for a gasket change, first attemp never messed wiv engines b4 but seems easy its only a 1600cvh on original carb, u were saying about using a dremel! i was thinking the same theres about 3mil of black shit oround the outlets an a bit on the inlet, if i was to use a dremel would i have to strip the full head ie vailves an so on?
cheers m8
rsvmad
Old Aug 23, 2008 | 06:29 PM
project rs's Avatar
project rs
he was joking about the dremel there is more to doing a head than matching ports together if its your first time with taking the head of then i'd just put it all back together and do some research into what you want from the engine in future and make sure it's a genuine ford head gasket you put back on with new head bolts
Old Aug 23, 2008 | 06:38 PM
crazycage's Avatar
crazycage
jamsports heads are really good mate
Old Aug 23, 2008 | 06:59 PM
project rs's Avatar
project rs
now you've opened up a can of worms hope all went well with wife and don't worry the baby will be ok she just needs loving care and she's in the right place for that
Old Aug 23, 2008 | 10:28 PM
Raj B's Avatar
Raj B
230bhp S2 in the making!!
cnc machined heads that have been calculated on a flow bench se to be the current trend, mine was done by cyliner head developents, stage 3 with s/s oversizedvales andmatched inlet, cost £800
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
caprixpack
Sep 25, 2015 07:53 PM
