cuting on boost.
Old Aug 13, 2008 | 07:22 PM
tore_tj's Avatar
tore_tj
Cossie Paranoia
Default cuting on boost.
hey.
my brother(tore_tj) has just bougt a escos and is now driving it from bergen(norway) and home. only problem is the car has started to cut on boost. he has tried to disconnect the amalvalve, but no improvment. if he puts the throttle careful to the ground then it seams almost fine, but still cuts a little bit.
any sugestions?
Old Aug 13, 2008 | 08:05 PM
Speedy G.'s Avatar
Speedy G.
Plugs
Old Aug 13, 2008 | 08:14 PM
Tony Rs's Avatar
Tony Rs
Ebony black Sapph Cos
Originally Posted by tore_tj
hey.
any sugestions?
Also sounds like it could be overboosting
Old Aug 13, 2008 | 08:18 PM
BigErn's Avatar
BigErn
Whats the spec of the car? Might help.
Old Aug 13, 2008 | 08:47 PM
AlexD's Avatar
AlexD
Post Miester !
Yes deffo sounds like boost cut or plug gaps
there are several reasons.
its colder at night so makes more boost which can push it over the limit, its prob running
at the limit...
plug gaps set too wide, and its blowing out the spark
plugs not up to the job, breaking down under the heat.
but usually is it goes ok under normal excelleration, then its probthe boost.
dont disconnect the amal valve as the engine needs it to regualte the boost.
i might over boost run lean and melt a piston, then GAME OVER !!!
what stage of tune is it ??
Old Aug 13, 2008 | 09:10 PM
tore_tj's Avatar
tore_tj
Cossie Paranoia
thanks for the replys. the car is an original t34.
Old Aug 13, 2008 | 09:13 PM
JHS's Avatar
JHS
Im guessing plugs too...
Old Aug 13, 2008 | 10:40 PM
saph cos rob's Avatar
saph cos rob
swindon rsoc
over boost and maybe plugs, mine was doing that as it was running on the limit when it was st2
Old Aug 14, 2008 | 11:03 AM
tore_tj's Avatar
tore_tj
Cossie Paranoia
ok. he will try some new plugs then. there is also missing a pipe on the amal valve. the left one, standing in front of the car looking down in the engine bay. could this have someting to do with it? he just noticed it.
Old Aug 14, 2008 | 11:41 AM
THE RADMAN's Avatar
THE RADMAN
left one is just the bleed off,if its got a cone filter then its just venting to atmos so will be fine
Old Aug 14, 2008 | 06:35 PM
tore_tj's Avatar
tore_tj
Cossie Paranoia
have tried to adjust the gap on the plugs now, but the car is still the same(actually a little worse). cuts at 4k rpm every time. the car strugles a lot when "hillclimbing"(sorry, bad english)
Old Aug 14, 2008 | 07:12 PM
JHS's Avatar
JHS
Maybe MAP sensor?
Old Aug 14, 2008 | 07:50 PM
Speedy G.'s Avatar
Speedy G.
Maybe the ECU is in "limp home mode" as you say it cuts at 4000 rpm all the time.
Old Aug 15, 2008 | 04:13 AM
stevecossy's Avatar
stevecossy
Is the escos amal valve the other way round to a sierra as its the right side pipe that goes to the airbox.
To be sure mate i would double check this, the amal valve is marked with letters on each pipe.
Also dont think the ecu has a limp mode on cossies.
Good luck. steve
Old Aug 15, 2008 | 05:35 AM
Daviet's Avatar
Daviet
deffo sounds like boost cut to me.my friends escos was doing exavt same thing and hes now had it on the rollers and boost turned back a touch and all ok now.
his was doing it at just over 3000rpm tho.is the boost guage on the bannana pod going up and over the 1.3bar max? as my mates was and just clipping the boost cut.
Old Aug 15, 2008 | 06:41 AM
rickbartlett's Avatar
rickbartlett
G911 TTA
defo plugs or plug gaps mate
Old Aug 15, 2008 | 03:52 PM
Ruudsengen's Avatar
Ruudsengen
Made In Norway
I would have tried another Map sensor. You could also try another set of plugs. I`m running NGK bcr8es. Never had any problems with those. 1,8-2bar/ 0,5mm gap
Old Aug 16, 2008 | 10:08 AM
jht's Avatar
jht
Intake air temperature sensor failing, ecu protects the engine and cuts at 4000 rpm
Old Aug 16, 2008 | 11:13 AM
tore_tj's Avatar
tore_tj
Cossie Paranoia
Hi. Thanks for the replies. I lost my license.. Guess I'm cursed with this car. On the bright side I now have six months to get the car how I want it. Bit depressed lol. The dreamcar turned out to be a nightmare.
Tore
Old Aug 16, 2008 | 11:37 AM
white4x4cos's Avatar
white4x4cos
Almost every sensor could cause this problem on a p8 then it goes into limp home mode(4000rpm).
Even lambda sensor or detonation sensor.
Old Aug 20, 2008 | 10:37 PM
tore_tj's Avatar
tore_tj
Cossie Paranoia
the car is just falling apart.. abs-unit is playing up and the rear hatch is lose for some reason.. rust around filler cap and through the back of the trunk. Regarding the performance of the engine, the car needs much cranking to fire.. 10 seconds isn't unusual. if it fires at all..
Old Aug 21, 2008 | 06:41 AM
JHS's Avatar
JHS
That doesnt sound too good... What car did you buy? Pictures?
Old Aug 21, 2008 | 12:38 PM
Dave Henshall's Avatar
Dave Henshall
lots of cranking and then running in limp mode (P8 escos do have limp mode) could be the bottom crank sensor. but more than likely if it hasn't already been done.... the 2 car loom to engine loom multiplugs at the front of the engine, right under the bonnet vent. these get full of water, ocrrode the pins inside and then all sorts of wierd stuff happens. you need to cut these out and solder them together 1 wire at a time and then insulate them , about 2 hrs work.
Old Aug 21, 2008 | 11:12 PM
tore_tj's Avatar
tore_tj
Cossie Paranoia
Hm.. that I'll try. Handy with the soldering iron
Old Aug 21, 2008 | 11:23 PM
tore_tj's Avatar
tore_tj
Cossie Paranoia
Pictures!
Sorry they're off my phone..
timsrs
Nov 13, 2018 11:48 AM
blackbeautyzetec
Aug 29, 2015 02:11 PM
Fiecos Dan
Dec 2, 2004 08:14 AM
Eagle
24
Jul 21, 2004 12:09 PM
EvilFranky
Jul 3, 2004 05:01 PM
