Peugeot 206 Rear Beam bearing
Old Aug 12, 2008 | 04:58 PM
trevCOSS's Avatar
trevCOSS
Default Peugeot 206 Rear Beam bearing
Has anyone ever replaced the rear beam bearings on a peugeot 206 the ones that the trailing arms rotate on? If so how difficult was it? special tools etc.
Old Aug 12, 2008 | 05:42 PM
PeterLucas's Avatar
PeterLucas
Yeah done a few when I worked at pug, was a few years back though. From what I can remember they were easy.
You might need a slide hammer to get the arm off, and mark the torsion bar on the arm before puching it out. Also Measure the height with the shock off between the centre of the hub and the top of the wheel arch, so you dont accidently lower it! (or raise it)
Old Aug 12, 2008 | 06:09 PM
ultimate's Avatar
ultimate
i do these quite often but find some are so badly worn that the damage is extensive and i just replace the complete rear axle with one from a breakers yard
Old Aug 12, 2008 | 06:24 PM
PeterLucas's Avatar
PeterLucas
Depends if water has got in or bearings have eaten into axle tube, Ive only ever completely replaced them on 106s for some reason
Old Aug 12, 2008 | 06:34 PM
Crowder's Avatar
Crowder
easier to replace the beam imo. easy on a 206!
Old Aug 12, 2008 | 08:20 PM
THEDMAN's Avatar
THEDMAN
This brings back memories of my 206 GTi when the main dealer said that the bearings couldn't be replaced on there own and I needed a new back end at £2500!
Bearings from an autoshop £18, Other halfs dad £100, job done!
jessie_rs
62
Aug 6, 2019 09:27 PM
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
