Compression Test Result on a Cosworth
Old Aug 12, 2008 | 09:48 AM
reisskahn's Avatar
reisskahn
Default Compression Test Result on a Cosworth
Hi can somebody let us know what kind of compression readings/results we should be getting from a 4x4 saph with around 106k (not too sure if its been rebuilt but know the top end has been done @90k)
On a dry test we got the following results:
Cyl 1: 160 psi
Cyl 2: 135-140 psi
Cyl 3: 140 psi
Cyl 4: 150-160 psi
On a wet test (dropping some oil into each bore/spark plug hole)
Cyl 1: 160 psi
Cyl 2: 145-150 psi
Cyl 3: 150 psi
Cyl 4: 160 psi
Car starts & drives fine no overheating, losing/mixing water etc...
The reason the test was done because it seems to give out blue'ish smoke now and then. When the spark plugs were removed for the test no. 4 plug was covered in Oil, is this normal?
Any input appreciated
Old Aug 12, 2008 | 10:12 AM
marco polo's Avatar
marco polo
Cyl 1: 160 psi
Cyl 2: 135-140 psi
Cyl 3: 140 psi
Cyl 4: 150-160 psi
Cyl 1: 160 psi
Cyl 2: 145-150 psi
Cyl 3: 150 psi
Cyl 4: 160 psi
im not sure but you might have oil getting past the rings or it might be worn valve guides /stem rubbers
marco
Old Aug 12, 2008 | 10:18 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
sounds like just general wear and tear on the rings particuarly on the middle two cylinders.
Exactly the sort of engine that keeps going forever at standard power, but dies very quicky at stage 3 IMHO!
Old Aug 12, 2008 | 10:49 AM
rapidcossie's Avatar
rapidcossie
Thought as long as they are all within 10% of each other its ok?
Old Aug 12, 2008 | 10:56 AM
reisskahn's Avatar
reisskahn
Forgot to add its a Stage 3 and what do you mean by it'll die what will happen like will it just sieze up or something?
Old Aug 12, 2008 | 11:05 AM
Chip's Avatar
Chip
Depends on what you mean by "ok"?
It will run, yes.
Old Aug 12, 2008 | 11:06 AM
Chip's Avatar
Chip
Nope, they NEVER seize in my experience, they just get smokier and smokier and slower and slower until you feel you have to eventually do something about it!
Dramatic failures almost never happen on an old YB if they are given regular oil changes and belt changes and pump changes etc, nothing that loose is EVER going to seize, lol
Old Aug 13, 2008 | 09:39 PM
reisskahn's Avatar
reisskahn
Any idea why i have oil in no.4 spark plug area?
Old Aug 13, 2008 | 09:41 PM
Rab's Avatar
Rab
Fucking superstar........
If they were all 1psi they'd be within 10% of each other So thats that theory fucked then
Old Aug 13, 2008 | 09:51 PM
xr_craig's Avatar
xr_craig
Good point, well made
Old Aug 13, 2008 | 10:10 PM
Spiky's Avatar
Spiky
if you knew my old saff you'd take that back
mine smoked as std spec ar 93k, at 100 it was stage 1, then 110k stage 3
348 and 14000miles later still goign strong, still smoking on hard throttle,
then i smashed it up
the engine is now going in a puma
but general you are right
Old Aug 14, 2008 | 07:23 AM
LHD220Turbo's Avatar
LHD220Turbo
if the spark plug was covered in oil, somthing isnt quite right, but the test dis-proves massively worn rings.
Maybe whip the head off for a look if you;re that concerned?
1300gt
Sep 7, 2015 12:06 PM
borboyous
Aug 22, 2015 11:17 AM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
Zoggon
Aug 10, 2015 10:39 AM
