Slipping out of gear...Vivaro!
Old Aug 10, 2008 | 03:19 PM
shane's Avatar
shane
Default Slipping out of gear...Vivaro!
I went to look at a vauxhall vivaro earlier and the guy said it slips out of 3rd sometimes and is diffucult when downchanging into third(doesent grind or anything, just stiff to engage). He said his mechanic said its just a worn linkage cable does that sound about right?
Help much appreciated.
Old Aug 10, 2008 | 03:37 PM
mechanic28's Avatar
mechanic28
bollocks mate gearbox is fucked!!!see loads of them at work
Old Aug 10, 2008 | 03:40 PM
shane's Avatar
shane
Defo the box then?
i just cant seem to find a decent van, its driving me around the bend. Loads in the dealers but they have your pants down on the price!
Old Aug 10, 2008 | 03:43 PM
mechanic28's Avatar
mechanic28
yes fella!they do suffer from a linkage problem but that dont cause that problem!early vivaros/movanos tend to eat gear boxes as the bearing end big,strong enough!later ones still have the problem but not as bad!
lozi's Avatar
lozi
My Cossie Ate My Money
i had this on my vivaro definatly fucked lol
btw i hated this van it was crap i had the 6 speed 1.9 and i hated it!
Old Aug 10, 2008 | 03:50 PM
jameswrx's Avatar
jameswrx
Yeah, as above sounds like he's trying to pull the wool over your eyes. My mate had exactly this problem too (and he had to have a new box) fookin unreliable van really, what with the common box prob his also just stopped running one day.. the fuel pump lunched itself and put swarf throughout the whole system and we had to replace everything!
Old Aug 10, 2008 | 03:52 PM
LHD220Turbo's Avatar
LHD220Turbo
the gearboxes in these are utter rubbish, down the workshop i use i've seen 5 of them with gone gearboxes
commonly they start to grind in 4th 5th & 6th - Ł1200 approx to get them rebuilt.
in fact the whole van is rubbish; get an X plate transit with the old style engine (think it was X reg the last year they done them on)
Old Aug 10, 2008 | 04:03 PM
shane's Avatar
shane
everyone says get a transit but i really dont like them, but with all the bad reports im getting about vivaros they are starting to look much better.
Old Aug 10, 2008 | 04:16 PM
jameswrx's Avatar
jameswrx
This is exactly what my friend has replaced his with.
To be fair when the van was running he liked it, he said it was a nice drive.. but the amount of hassle he had with it was unreal, and after searching the internet for advice about his problems we found many other cases.
Old Aug 10, 2008 | 06:19 PM
LHD220Turbo
to be fair not many manufactures make a decent diesel any more, IMO they;ve tried to over complicate something that doesnt need to be over complicated.....its a works van at the end of the day!
take the vivaro for example; it has air con, 6 speed, sat nav etc.....its just more things that can go wrong...they cant even get the mechanical things right such as the shite gearboxes
go for a transit; proven and quality, although the later ones do seem to suffer from diesel pump problems
Old Aug 10, 2008 | 06:26 PM
NEIL A's Avatar
NEIL A
I had been helping my mate look for a van for months and as you say there is loads of scrap out there advertised as mint.
Another problem we seen on vivaros was them being real sluggish when cold , but ran fine once heated up.Anyone had this problem before ??
Old Aug 10, 2008 | 07:24 PM
LHD220Turbo
Another problem we seen on vivaros was them being real sluggish when cold , but ran fine once heated up.Anyone had this roblem before ??
seen this before too; could have been a coincidence but the one i saw had injectors problems; but they were so difficult to get the injectors out, it was almost as if they were welded in there, had to get them machined out in the end
so keep way from this van, utter shite!!!
Old Aug 10, 2008 | 07:25 PM
mechanic28's Avatar
mechanic28
that will be number 4 injector!full strength coke works a treat on them
Old Aug 10, 2008 | 07:39 PM
LHD220Turbo
tried that! the thing was not coming out..and from memory i think it was no.4
Old Aug 10, 2008 | 07:41 PM
mechanic28's Avatar
mechanic28
its always number 4(the one nearest the cambelt) chap they get all the water on them,bloody poo!!!
Old Aug 10, 2008 | 07:42 PM
LHD220Turbo
thats it; i remember the guy telling me its so poorly designed it gets pissed on all the time from all the water
Old Aug 10, 2008 | 08:43 PM
NEIL A's Avatar
NEIL A
We looked at a few sites on the net and a few had said the air flow meter causes similar peroblems , but would think it would be more likely to be a temp sensor.
I take it #4 injector gets corroded and doesnt fire untill there is some heat in it ?
Old Aug 10, 2008 | 08:53 PM
LHD220Turbo
no.4 injector stopped working all together on the one i saw; and it wasnt the first one my mechanic mate had seen, they are just shite vans all round
just steer clear; get a merc/ transit van if your looking for a van
Old Aug 10, 2008 | 09:02 PM
eddie_od's Avatar
eddie_od
stay clear of the vivaro, heaps of shite is about the best thing i could say about them.
had 2 and both ended up with fucked gearboxes, thank fuck it was contract hire.
out of all the vans ive had id say sprinter or transit are best option
krypton
Sep 23, 2015 07:29 PM
liam-rst
Was It You?
Sep 5, 2015 06:38 AM
mint_s2
Sep 2, 2015 08:58 AM
