2 pics of my mk2 escort project
Hello, here is a couple of pics of my MK2 Escort 1600 sport. i had a mk2 escort pop plus which i used for a while back in 2005 until the M.O.T (bent me thinks) ran out, i stripped it down and had it shot-blasted and there was nothing left of it so i did a part-ex on it against the car you see in the pics with a bloke who deals in old skool fords. this was all about a year and a half ago and the car came stripped down and needing lots of welding but not as much as the pop plus + parts. A chap local to me who only restores old Fords did all the welding and paintwork and im putting it back together! wish i could say i did it all and although i can weld and sort of paint i wanted it to be to a high standard so had to pay somebody else basically! thats the story in breif! i have loads of pics of the resto but these pics show how the car is now.
I'll put a spec up for anyone who wants to know/cares?? lol
Goodluck on that project mate. I'm sure it will be a blast. Are you going to repaint it? I don't like the color. lol...
_______________
Must read: Autopartswarehouse.com
_______________
No im not going to paint it. ive wanted an orange flatfront mk2 escort since i was about 16, im 23 now.
Brief spec is: ENGINE AND GEARBOX: Rebuilt standard 2.0 pinto bottom end with lightened and balanced flywheel, stage 2 head with piper cam and vernier pulley. Type 9 gearbox with Quiafe rose jointed quickshift, 1 peice prop, English axle with TRAN-X LSD.
INTERIOR: 6 point Safety Devices rollcage with door bars, corbeau Pro Series bucket seats, flocked steering cowling and dash top, OMP Corsica steering wheel(not 1 in pic!), carbon fibre doorcards and rear quarter cards.
BODYSHELL: New wings, splash panels, inner sills, outer sills, front floors, rear panel, rad crossmember and slam panel! also 5 linked and turreted at rear.
SUSPENSION & STEERING: Bilstein coilovers on the front, AVO coilovers at the rear, 2.4 turn quickrack and green track rod ends, polybushed at front.
Also got some 6X13 revolutions to go on but really want some 7's. still gotta get my front brakes aswell but will probably be wilwood 4 pots.
Hello dave, yes mate. just finished getting all the back axle on and running all the brake lines. just waiting on my exhaust and inlet studs so i can get my 4 branch and twin carbs on! Those seat brackets are on order aswell!
Finally got some more pics. Got my carbs and exhaust manifold on as the studs finally turned up. got the cambelt on aswell after i took the pics.
Not sure if i should fit a carpet or not? there is a couple of rough bits in there so they would obviously be covered up by the carpet but im fitting bucket seats and already have a cage in there. if i dont fit the carpet then im definately gonna have to get some more orange on the floor but i have 2 litres left so no probs there.
My mate should be fitting the 1600 sport graphics in the next couple of weeks also so i'll get more pics when that is done.
DAVE COS4X4 Cheers mate, likewise with yours.
BRIGSPORT Yes mate, im 90% sure its a Capri one. the sierra one has another take off that runs to the header tank i believe.
No it doesn't, the sierra take off is in the top hose itself. The difference between sierra/capri and mk2 is the angle of the housing. The mk2 is less vertical. HTH.
COOSIE DAZ. Cheers fella, will do. I'll be doing a bit more tomorrow as the weather is supposed to be good.
TIMGR I initially wanted the whole car orange including underneath with the axle black but thought about it a bit more and i cant justify jacking the car up to wash it nearly everytime i use it! The cage was gonna be black but i like it in orange against the black window surrounds.
Doh - just looked closely at ur pic above only to find you have dellortos......cant remember the pressure setting off the top of my head but you will still need a pressure regulator.....a Facet Redtop pump for example runs 7PSI and will just flood your engine or overcome the floats and piss out the over flow....
again id recommend a filter king with a pressure gauge
Nice clean solid looking car
COSSYMAX Thanks for your help. This is starting to make sense. ive always had old fords but never mucked about with twin carbs, just single webbers!
P.S. Your on turbosport aint ya? Love the Tina!
CheeRs Mate , And yes i am on turbosport and oldskoolford!!!!
There is a tech forum under WPE on oldskoolford...
And Nice project you have there
COSSYMAX Thanks mate.
FEZZAJSY Not quite perfect, there is a few bits im not happy with but then again if it was to good i'd be a bit scared to use it and i want to get her on the track aswell.
Your saff looks tidy!
Wow....its looking good.
By any chance did you have a red one or was it red as i lived at the top of Stuart's road, and saw a red mk2 down their (this is ages ago).
You got any more pics of it???
Fraza
Fraza
FRAZA91 yeah that was ages ago. i stripped the red one down and the shell was a wanker (rotten!) so i kept all the good bits and some, spoiler, running gear, diff, fishnet recaro's ETC.. and got another rolling shell. I sold some of the old good bits to pay for the new shell and kept some bits for this one.
Who are you then? did you live next door to Sadie?
Yeah i lived on the corner at the top two doors awy from sadie.
But yeah i have always liked mk2 escorts since (sounds sad) the day when i saw u bomb it down the road..i said to me dad get me one.
And we almost did but we moved..argh!!..so yeah im saving as much as poss to do a mk2 project.
when you think it will be finished then.
You know Ryan Walsh don't ya.
Fraza91
Fraza91
Haha, yeah i did tear it about a bit mate, mainly because it sounded so good!
I hope to have it finished around april/may, before the summer basically so i can get it to the shows and stuff.
Yeah im good mates with Ryan, i only live 2 roads away from him.
Keep saving mate, they're bloody expensive but it would good to get some more old school fords round here as there aint a lot. i dont mind helping out once mine is done as i know i'll be bored when ive finished it.
Tell me about it, Yeah i work wit him and i onli live couple roads from now..livin wit me grandparents
I got a couple of mates who want the mk1 escort but i def gonna get a mk2...well i hope lol.
cool cool will keep that in mind.
Im lookin into goin to an old skool/retro ford day seen pics on websites..some of the car are mint!!
