std air box or k+n filter?
Old Aug 6, 2008 | 06:58 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default std air box or k+n filter?
i have k+n filter on the s2 but was going to put the old airbox back on? what is best people?
Old Aug 6, 2008 | 07:02 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
tbh maybe the airbox cos u dont get as much hot air from the turbo.jamsport did a test on this and found a drilled airbox made made more bhp
Old Aug 6, 2008 | 07:07 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
i thought this i drove to silverstone on sunday, hand felt the k+n and it was hot to be fair. ill buy a std airbox, do i need to get the clips to fit it down?
Old Aug 6, 2008 | 07:13 PM
rickbartlett
G911 TTA
cant remember how it secures down,but its a tite fit over the air intake neway so it will hold it down anyway mate
Old Aug 6, 2008 | 07:17 PM
RST_Rob's Avatar
RST_Rob
there held down with a 10mm blot and tourqe sqrew (thats how mine is)
Old Aug 6, 2008 | 10:39 PM
Raj B's Avatar
Raj B
230bhp S2 in the making!!
i read a review in one of the rags and out of all the expensive filters, the standards box with a replacement panel and drilled holes gave the most bhp, but remember these tests were at static with only fan at the front of the car, imo if you properly protect the filter from heat soak and apply some good air ducting then that is the way foward
hope this helps
Old Aug 6, 2008 | 10:49 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
its worth loosing a couple of BHP for a K&N as the airbox looks wank,esp with holes drilled init!!
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
155lee
Oct 27, 2015 04:55 AM
markk
Sep 9, 2015 08:11 AM
Rizlablue
Sep 6, 2015 09:58 AM
gavt123
Sep 5, 2015 10:03 AM
