fuel pressure regulator
Old Aug 5, 2008 | 02:29 PM
sideways dan's Avatar
sideways dan
Default fuel pressure regulator
does the fuel pressure regulator on a 2000 2.0 zetec engine rely solely on the vacuum from the inlet manifold to open it or does the fuel pressure also play a part. for instance would it stay closed if there wasn't enough fuel pressure?? thanks in advance, dan
Old Aug 5, 2008 | 03:22 PM
JesseT's Avatar
JesseT
It's always the pressure difference that opens the recirculation outlet. fuel pressure minus manifold pressure. The later engines didn't have a pressure regulator though. Think they just controlled the the pump voltage.
Old Aug 7, 2008 | 07:36 AM
It's always open, but closes up a bit to increase pressure when needed, ie accelration etc, it senses this change through vacuum, recirculating the fuel all the time keeps it cool.
timsrs
Nov 13, 2018 11:48 AM
SMILER258
Sep 28, 2015 09:04 AM
Dubs44
Sep 19, 2015 06:31 AM
