escos 2wd conversion
Old Aug 7, 2008 | 11:35 AM
h5kcd's Avatar
h5kcd
Question escos 2wd conversion
just done conversion on escos to 2wd and ive used 2wd engine but i am having a few problems, 1st i can not get the revs down bellow 1250rpm ive unplugged isv and i can get revs down as far as 900 but when i put plug back on isv it goes up to 1250rpm, 2nd two wires for oil pressure on escos but only one sender switch is there any way round it any one help cheers
Old Aug 7, 2008 | 11:46 AM
graham c's Avatar
graham c
which wirin loom you on 2wd or 4wd ?
Old Aug 7, 2008 | 11:55 AM
h5kcd's Avatar
h5kcd
hi i am on 4wd loom and i have changed the two outer wires round on tps cheers
Old Aug 7, 2008 | 12:11 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
Which ECU and TPS are you using?
Old Aug 7, 2008 | 12:13 PM
h5kcd's Avatar
h5kcd
im using 2wd l6 ecu and tps cheers
Old Aug 7, 2008 | 12:25 PM
Daveysaff's Avatar
Daveysaff
I'd try checking the phase sensor gap for the idling problem, mine idled around 1500 when it was out, worth a try? As for the OP switch, afaik thats not part of the engine loom and only goes to the clocks anyway, so i'd just try and connect one of them and if it doesnt work, swap them round
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
