Where did my BHP go?? Rolling road graph....
I went to Powerstation today for a rolling road day with another forum. The place is to be fair pretty awesome - very swish and clean with friendly staff.
Right my car was run on the rollers with me and another well fed chap sat in the back, and in 5th gear. I wondered about this as I thought dyno runs are usually done in 4th, but the guy said it was to stop wheelspin. Temp in the dyno room was mid 20 degrees.
I was expecting to make around 370-400 BHP and about the same torque. (I know 400 is optomistic, but the car is quick on the road.)
The car is standard comp and cams - basically stage 3 and a bit - T34.63, -34, Siemens Blacks, 25/26mm ported head, RS 500 cooler, grp A cone filter and a Karl Norris livemap on L6 mapped to 32 psi peak 28 midrange and 24 at the limiter. Karl said when he mapped it its a good one.
The fucking old shed only made 325 bhp and 353 lb-ft. Where the hell has 50 bhp gone? It drives fine - smooth as ever, is not using anymore oil than is usual with these, economy is unchanged, no missfires or stuttering, yet I've lost 50 fucking horses.
The graph looks fine to me, shape wise:
I asked him to stop @ 6.5k as I'm on track tomorrow @ ford fair and didn't want any damage, and power is still climbing but looking at how shallow its climbing its not gonna go past 335 before the limiter.
So, is my engine fucked? Was I being deluded expecting that kind of power? Do powerstation's rollers read low? Something else?
Its not making anymore power than it would have done on a bloody T3!!
Personaly I would'nt get too hung up on the figures as long as the car feels good then happy days - just enjoy it.
Remember the figures shown relate specificaly to that set of rollers on a given day with a specific set of circumstances, gear ran, diameter of rollers,ACT temps etc etc.
Whether one set of rollers reads right or wrong whether they are higher or lower than another is neither here nor there really - you just can't compair with any degree of accuracy one set of power figures with power figures from another rr'd.
dynos have to be calibrated and this is done to there descretion, you could go to one dyno and get whatever bhp, torque etc then go to another dyno around the corner and get different figures all together. maybe because the second dyno is slightly older (out of calibration) add that to ambient air temp crap then you have an answer..
also just had to add that just noticed that powerstation is home of dirk and rich, before they opened powerstation they owned a company call autopoint based in thetford norfolk (about 7 miles from me) and i can tell you those guys know there stuff trust me and if they dyno was out of calibration i would be surprised as i have used them myself a few times.
oh yes, they were great (autopoint)
one of my friends spent a large abount of money with them to get an unreliable 200bhp rs turbo
never again
NEVER EVER take your car to a RR if you are a number chaser.!!!!!!!!!!!!!!!!!!!!!!
If it drives good on the road then it is fine.....
I thought it should be done in 4th tbh....
Charge temps will play a big part.
Cheers for replies chaps!
Feling bit more positive now, if it all seems reasonable.
I'm not necessarily after "x" number, 370, or at least 350+ was just pretty much what I expected. I was more concerned there was something seriously wrong with the engine as 325 seems low for the bits on the engine. I'll see how it feels on track tomorrow - hopefully it won't go bang
what have others seen from a similar set up?
Feling bit more positive now, if it all seems reasonable.I'm not necessarily after "x" number, 370, or at least 350+ was just pretty much what I expected. I was more concerned there was something seriously wrong with the engine as 325 seems low for the bits on the engine. I'll see how it feels on track tomorrow - hopefully it won't go bang
.what have others seen from a similar set up?
Karl did say when he mapped it that he drops it at the top to get a bit more life out of the turbo, otherwise it might only last a few months. I do like the way the torque comes in in the midrange on this set up.
Compare your wheel power there to the last print out you have for the run in 4th gear. Running in 5th will give you less wheel power due to the gearing.
Also ambient 26.5 is quite warm so you may lose some there.
It hadn't been run on the rollers after mapping, this was the first time on this set-up. I was wondering about 5th gear, as I thought usually they're done in 4th.
Meh. It seems to go OK on the road, I was just hoping for a bit more. Time to save for a new engine I think.
First time on track with it tomorrow too.
then he had another tweek and it ended up 189bhp
useless twats i lost 20 odd bhp that day!
maybe your car was boosting to high first run, maybe detonation, to rich, to lean, im sure once all of these factors where taken into account the rs must have felt smoother, better through the mid range?
no?
i spent 7k with ray at autopoint on my s1, this was about 10 years ago mind you and had 203bhp at flywheel and 170 at wheels he done me justice that was at 14psi
Read what Tiff & Mart said - if it feels good on the road TO YOU, then - IT IS. Numbers are a by produdct NOT to get hooked on....... Real
world Power delivery can be so different to a set of peak figures on a graph......
I have a Karl Norris stage 3 chip and he told me that when the ACT gets above 55F the ignition is retarded by 11 degrees, your ACT was way above that. could that have something to do with it?
yeh ray took over from durk and rich they moved on...
no?
no?
foxy you didnt live in Brandon did you?
Ray at autopoint is a F*****G builder, he happens to own a small garage in Harleston, but he went from being a builder to a RR operator!!
My escort mk2 auto gained 23bhp after his tune up, ie when it was done PROPERLY, maybe that is why he is now SHUT ?
He still does diesel chips from his farm though.
Dirk and Rich, are very likeable chaps, who I also used, they could do a good job, IF THEY COULD BE BOTHERED, they weren't always bothered, but could turn out good work, many disgruntled customers with ray though.
He ran my MODIFIED escort at std ignition timing, when I enquired about a timing swing he said "not needed", different CR, different cam, different carb, different head, different exhaust.
I restricted the max advance by bending the pegs in to stop weights moving out so far, then gave it another 6-8 degrees initial advance, after farting around for a whole day it was perfect, and a subsequent run on RAY's rollers showed a 23bhp gain, 4 days later.
like you say 400 a bit optemistic on a t34?
either way, 350lb ft sounds good.. sounds like it was an ass dyno estimation
when you said 370-400? if so then your dyno is out a little bit mate
350lb ft in the heat is pretty good! ambiant temps of 20odd, charge temps probably in the 30s or possibly higher?? when the car has been sat around for a few mins on the rollers.
so IMO its a realistic figure for the conditions.*
* needless to say, im no expert, and have very limited experience, lol. but im sure its fine
heat soak into an intercooler is huge when the cars are just sat around after you switch them off, just prior to being driven onto the rollers.
i'd say thats bang on.you can tell if a car doesnt feel right. mines lazy and has no low down get up and go but you can feel the engine wants to what its meant to. it managed 369 but its a very lethargic 369.even though its that power my old saff at 350 would whoop its arse,down to the way it pulled strong.
if it feels good and strong dont worry about it.
saff is working!!!...atm
Before people start slagging off the dyno they need to spend a bit of time and use the god given right to read up on how MAHA RR's calculate their figures.
They are quite different to a Dyno Dynamics RR for instance.
Ignore the drag and atw figures, unless you are comparing against another MAHA using the same latest software. The Flywheel figures are comparable with a Dyno Dynamics RR. The RR software is designed for flywheel figure production, NOT ATW production.
Running in 5th on a MAHA would slightly affect the end figures, but on a RR day they will run the quickest method known to get traction, which makes sense when you are running a lot of cars.
Ironically some people in the Scoob world of tuning had suggested my figures had been inflated using PS's RR with my Spec C build (so I heard on the grapevine). That was until I ran it on another rolling road which measured 440bhp / 470lbft at the hubs!
That put paid to that one. lol
The cooling / airflow for the dyno cell is also one of the best I have seen in the country.
But as people have already said, it is how it drives on the road that counts.
That put paid to that one. lolThe cooling / airflow for the dyno cell is also one of the best I have seen in the country.
are you saying that cars dont suffer from trans loss or you mean that they dont suffer from it as much as people think? i was still under the impression that they suffer from transmission losses, please dont kill me.... i seriously dont know.
Drove to FF today and all seemed ok, was out on track @ 9:40 with the central group. I was dropping boost all the way through the session. I initially thought it was because it was so slippery and so I was wheelspinning and couldn't load up the engine. Then there was a big bang and no more boost at all and clouds of black smoke out the back from over fuelling apparantly. Naturally I shat myself and wondered how many grand this was going to cost.
I found this:
That's the turbo to intercooler pipe, blown to bits!!
Is it likely there may have been a small hole in this for a while which was causing a boost leak, then it got weak and went all of a sudden? Silicone hoses don't just go bang like that do they?
Put on a new Roose one at FF and the car is perfect again. Cheers to Rapid Ford for knocking a few quid off the asking price as I needed it to get home and had not enough cash on me!
I'm now not too fussed by the figures, I think everyone is right in saying that its how it drives that's important, not what it says on a bit of paper. I'm just wondering if it may have been split yesterday causing a bit of a leak, hence making low power.
Still all's well that ends well.
I found this:
Regards Dave R.
is it was a small leak then the turbo would have been overspeeding to compensate on the RR this might have increased the charge temps and the ecu may have backed off the ignition resulting in a lower figure.......................
OR I could be talking shite lol
