clutch or gearbox troble t2wd cossy
Old Aug 1, 2008 | 06:15 PM
abdr500's Avatar
abdr500
Default clutch or gearbox troble t2wd cossy
right on my cossy 2wd was in 1st gear gave it a bit and now i cant get it into any gear with the engine runing i have to switch it off and start it into gear and it goes to drive once driving you can press the clutch and the car is still going what do people think i think its cltch
Old Aug 1, 2008 | 06:33 PM
jaimesdna's Avatar
jaimesdna
could just be the clutch cable or ratchet. very common problem on fords
Old Aug 1, 2008 | 06:41 PM
LHD220Turbo's Avatar
LHD220Turbo
try a new clutch cable; very common for them to stretch
Old Aug 1, 2008 | 07:13 PM
BigErn's Avatar
BigErn
Ratchet and pawl may have gave up. Only pennies to buy if it is the case.
Old Aug 1, 2008 | 11:25 PM
abdr500's Avatar
abdr500
the cable is fine so s the pedal box coz the arm on the gearbox moves full travel and ther is resistance on the pedal
Old Aug 1, 2008 | 11:49 PM
marco polo's Avatar
marco polo
hi mate
the cable might have stretched that would cause that not getting any gears aswell as the clutch
marco
Old Aug 2, 2008 | 07:00 AM
Did you put some proper grease on the splines of the friction plate, if this sticks it will also cause it.
Old Aug 2, 2008 | 08:59 AM
Dan@Rapid-Ford's Avatar
Dan@Rapid-Ford
I had this in my car ages ago, out playing on a ind est near me ended up being the clutch plate stuck to the flywheel got it on video too
Old Aug 2, 2008 | 09:05 AM
fuzzy's Avatar
fuzzy
14000+ post superhero
so common that i gave up after 3 new cables in 18 months and went bmw hydraulic on my t5 box.
Old Aug 2, 2008 | 10:33 AM
jaimesdna's Avatar
jaimesdna
mine eats cables for breakfasst dinner and tea, so much so that i always keep a spare cable in the car lol
Old Aug 2, 2008 | 11:47 AM
Dan@Rapid-Ford
I don't get why people have so many prob with clutch cables and ratchets
In 10 years of owning Cosworths I've had the ratchet go once at ford fair replaced and didn't happen again and can't remember snapping a cable.
My Brothers car snapped a cable once in 8years and once replaced didn't do another
Old Aug 2, 2008 | 08:22 PM
abdr500's Avatar
abdr500
dont peolpe read the post i siad thers pedal presure and the clutch fork moves to its full trevel i think its gear box
yatta
May 21, 2016 10:31 PM
jamie956
Sep 18, 2015 12:04 PM
talon1
Sep 15, 2015 10:27 AM
Flateric_2002
Sep 15, 2015 08:41 AM
gingeRS
Sep 4, 2015 06:29 PM
