Ignition coil !!
Hi
I am having a bit of trouble understanding Haynes explanation or wiring diagram for the ignition coil setup.
I need to connect the Gotech ECU to the coil but there is no plus or minus sign on the coil, only pin no. 1 and 15.
Reading the Haynes manual is obly making me more confused. Does anyone know whats plus and minus
Henrik
Henrik
15 is ignition live (Positive (+) side of the coil) green wire on the standard loom
1 is pulsed earth from ignition ECU (Negative (-) side of the coil) black wire on the standard loom
