RS Problems :O
Hey guys,
Just thought I would put my problems up here. Got a couple
which hopefulyl someone can help with
1. When she starts up she very rough until warm and runs fine boosts etc perfectly. I thought cold start? But not sure where to start etc hope someone can help.
2. Car just wont tick over right it always dying or running at very low revs around 400-500, as soon as you touch throttle lightly it fine, I got a new throttle cable so adjusting this may work? Or I got told crankshaft sensor?
Hope a can get help here too.
The engine is coming out anyway as I need to re shell so work on it then so wont know if works till it back in car
but will give you all a shout let it know what happened
. Thanks again guys!
Hi mate,
i didnt want to muck about with that haha not good with engine things just the easy parts :P and car just been setup up on rolling road lol that why I havent gave that a thought as I just put a new actuator on and sent it away for the power gains
the idle screw wont do too much damage mate, maybe just adjust it so it can idle nicely for the few days it takes to get it to a garage. and dont give it death until its sorted though
what you'll find is if you mess with the screw, and its not the problem then it really wont fix much anyway, so you can just turn it back.
Start the car up then slowly turn it clockwise - you will hear the engine revs increase as you turn (may take a few twists before it starts to alter) then set it around the 900rpm mark.
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
