RS Problems :O
RS Problems :O
Hey guys,
Just thought I would put my problems up here. Got a couple which hopefulyl someone can help with
1. When she starts up she very rough until warm and runs fine boosts etc perfectly. I thought cold start? But not sure where to start etc hope someone can help.
2. Car just wont tick over right it always dying or running at very low revs around 400-500, as soon as you touch throttle lightly it fine, I got a new throttle cable so adjusting this may work? Or I got told crankshaft sensor? Hope a can get help here too.
The engine is coming out anyway as I need to re shell so work on it then so wont know if works till it back in car but will give you all a shout let it know what happened . Thanks again guys!
Hi mate,
i didnt want to muck about with that haha not good with engine things just the easy parts :P and car just been setup up on rolling road lol that why I havent gave that a thought as I just put a new actuator on and sent it away for the power gains
S1 Database Editor
Start the car up then slowly turn it clockwise - you will hear the engine revs increase as you turn (may take a few twists before it starts to alter) then set it around the 900rpm mark.
Hey thanks guys, much appreciated!! I thought that screw changed fuelling etc OOPS!! Engine out now but I will have a try when it in new shell guys thanks again!!
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
