mk5 xr3i alternator trouble
Old Jul 30, 2008 | 03:31 PM
mstar641's Avatar
mstar641
Default mk5 xr3i alternator trouble
Sorry if this sounds a wee bit stupid but its my first ford... I need help fitting an alternator belt. The cars a mk5 xr3i 1.8 130. I need the route and where the tensioner is. Pics would help loads.
Cheers.
Old Jul 30, 2008 | 06:03 PM
Cozziekid's Avatar
Cozziekid
does it have power steering or air con?
Old Jul 30, 2008 | 06:19 PM
Cozziekid's Avatar
Cozziekid
PAS - power steering pump
WP - water pump
G - guide
GEN - alternator
T - tensioner
CS - crankshaft
AC - air con pump
Tensioner should be a 15mm socket/spanner and is spring loaded
turn it clockwise if i remember untill you can slip the belt off then slowly let tensoin off. To refit just turn clockwise again untill you can slip the belt back on.
Easy peasy
Old Jul 31, 2008 | 05:07 PM
mstar641's Avatar
mstar641
Cheers bud this is what im needing. But its not got AC. Do you have a pic for that?
Old Jul 31, 2008 | 09:53 PM
Cozziekid's Avatar
Cozziekid
Just ignore the AC bit of the diagram then mate and the belt will go from GEN across to CS instead.
Old Aug 1, 2008 | 02:19 PM
mstar641's Avatar
mstar641
cheers buddy will give it a bash. Have you had one?
stephenb4506
33
Oct 2, 2015 06:25 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
