small turbo missfire, what causes them
Old Jul 29, 2008 | 07:36 AM
The Youth.'s Avatar
The Youth.
Default small turbo missfire, what causes them
I have an on boost missfire that has recently started, I changed the plugs thinking it was that to no avail, it only does it when it's hot which leads me to think that one of the coil packs is on it's way out, can these be tested?
anyone got experience of this?
cheers
steve
Old Jul 29, 2008 | 12:22 PM
Robski's Avatar
Robski
mine did this along time ago,changed the coil pack and it cleared up....i'd try and find a spare one off Ebay and try it
Old Jul 29, 2008 | 12:33 PM
llw's Avatar
llw
mine was doing this for a long time
got some coil packs off ebay but still the same
then decided i gonna mix and match the coilpacks and see what happens, on the first go it was fine, been fine ever since over 9 months and massive 150 miles probably since
Old Jul 29, 2008 | 05:13 PM
oilcosworth's Avatar
oilcosworth
Mine also dun this i found it to be a coil pack as well
got mine off dunc at www.automotiveunlimited.co.uk
Old Jul 29, 2008 | 05:45 PM
stevev6's Avatar
stevev6
Check the wiring around the tops of the coil packs and the connectors. Mine were bare just after the wires went into the coils itself. Really poor for this.
Also look at the multi plugs just under the header tank, grey and black 1s i think. If they are corroded etc clean the terminals etc.
Steve
Old Aug 7, 2008 | 07:26 AM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Off to Stu now then mate?
Old Aug 7, 2008 | 07:10 PM
MarkN's Avatar
MarkN
Have you checked the plug gaps? Small turbos are very sensitive about the plug gap. I had a bad missfire on mine on boost and regapping the plugs fixed it straight away.
Old Aug 7, 2008 | 09:45 PM
AJC's Avatar
AJC
broken down coilpack?
Old Aug 7, 2008 | 09:47 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
Steve gis a ring fella 07876 481 735
i might be able to help in me un-experienced guessing way lol
Old Aug 7, 2008 | 11:33 PM
cosworth3d's Avatar
cosworth3d
I had that as well ,one coil pack let go i changed that all fine
Matt Baxter
Sep 16, 2015 08:30 PM
Cosnada
Aug 27, 2015 09:15 AM
IAN RS2k
Aug 18, 2015 07:51 PM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
ginger1979
Jul 31, 2015 09:56 PM
