central locking problem
Old Nov 3, 2004 | 12:45 PM
AJC's Avatar
AJC
Default central locking problem
my passenger side door does not always lock, it always unlocks,
all connections are good so that is not the problem. has any one
else had this problem with there series 1 or 2.
i think it could be the solenoid.
open to suggestions
Old Nov 3, 2004 | 04:38 PM
RS_JAY's Avatar
RS_JAY
Same probs here.
Think its the actual lock. When you turn the key, the passenger door cant lock & gets confused, so opens up the drivers side. Well thats whats up wiv mine anyway.
Old Nov 3, 2004 | 09:45 PM
Gr8Ride's Avatar
Gr8Ride
My passenger side doesnt open or lock at all from the drivers door
Old Nov 4, 2004 | 03:38 AM
kevsrs's Avatar
kevsrs
Mine done exactly the same thing and i changed the solenoid. Since then the passenger door doesn't respond at all to the driver's door even though the boot works fine and it was a new solenoid so i just gave up
Old Nov 4, 2004 | 06:28 AM
JesseT's Avatar
JesseT
S1 and S2 systems are so different you can't compare them. With the S1, start by finding the central locking module in the front foot-well and clean and inspect all the connections.
Old Nov 4, 2004 | 10:59 PM
AJC's Avatar
AJC
cheers lads, i dont lock car with key at all, just
use the alarm fob, i will try it with key and see
what happens.
Old Nov 5, 2004 | 09:00 PM
SI-S1's Avatar
SI-S1
my s1 doing it as well
Old Nov 5, 2004 | 09:02 PM
s1rscustom's Avatar
s1rscustom
clean the earths up in footwell drivers side. i had same problem none of mine was workin and behind the door rubber 2 wires were split id check behind both rubbers just pull them back and check what they like
stephenb4506
33
Oct 2, 2015 06:25 PM
DAZZER
Sep 30, 2015 08:43 PM
rsguy
44
Sep 29, 2015 03:29 PM
