how much power on mfi
Old Jul 22, 2008 | 08:33 PM
Smartdj.'s Avatar
Smartdj.
Unhappy how much power on mfi
how much power can u get out of mfi safely....or should i just conver to efi for more safe power
Old Jul 22, 2008 | 08:47 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
The air flow meter itself doesn't flow more than about 230-240hp worth of air, but each metering unit differs in how much fuel it can supply.. anything from about 170 to 220hp!
Basically you get it set up somewhere and they will tune it to the max safe (hopefully)..
Old Jul 22, 2008 | 09:01 PM
Smartdj.'s Avatar
Smartdj.
will that be with fith injector...i dont really want to mess with that sort of stuff..thanks for the reply
Old Jul 23, 2008 | 08:51 AM
Antti O's Avatar
Antti O
I do recommend programmable EFI injection system and wasted spark.
Ke-jetronic ignition controlling arent sharp enough when pushing more power out of the engine and fuel managment is bit rough. I think ke-jet was invented in 70´s..
my ex rst has 180ps with ke-jetronic and it everytime dropped little lean when pushing hard and only 10psi of boost. This way i destroyed more than 2 engines, 4 conrods and 4 pistons.
Then i get programmable efi and after then there is no need to open engine any more.
And this only when some professional has been mapping the controller with wideband afr system.
Now i have "new" hobby car.. RST naturally and i megasquirt & wasted spark system installed waiting for proper intercooler & new better injectors and then proper mapping for EFI.
Old Jul 23, 2008 | 08:09 PM
Smartdj.'s Avatar
Smartdj.
oh my god now the whole engines stoped running ...someone said it could have bin valve meeting piston...but i thought it was bottom end...and now it wont even run at all...or turn overwhy me...lol....oh god moving house in 3weeks ..could it get worse...sshhhhhhiiiiiiiitt
Old Jul 24, 2008 | 09:45 PM
Smartdj.'s Avatar
Smartdj.
i think im goin efi as soon as i cAn aford it....so ill need head...inletmanifold...pipes..plus charge pipe maybe....whT ELSE?...ECU
Old Jul 25, 2008 | 01:53 PM
mk3cab's Avatar
mk3cab
with a fifth injector i am running 267bhp with an afr wideband meter and it dont lean out at all at top end. @16 psi
Old Jul 25, 2008 | 02:15 PM
Smartdj.'s Avatar
Smartdj.
sweet where can u get the fith injectors from ...will most tunes no how to fit and setup
Old Jul 25, 2008 | 02:33 PM
phil_rs's Avatar
phil_rs
yam yammer
My mate used to run 247bhp @ 14psi on mfi using a 1.9 tall block.
Old Jul 25, 2008 | 11:41 PM
Smartdj.'s Avatar
Smartdj.
wicked im liking the sound of that....i think im going to need cossie brakes for sure now.........it might be ready for ford fair.....fingers crossed
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
Iain Mac
Sep 30, 2015 09:39 PM
dojj
Sep 29, 2015 10:32 PM
deathrider666
Sep 28, 2015 06:12 PM
