curious boost behaviour
Old Jul 22, 2008 | 08:21 PM
an1mal_69's Avatar
an1mal_69
Default curious boost behaviour
when the car comes on boost it holds 10psi..as it passes 4000rpm, boost starts to rise with engine revs topping 20psi @ 5500rpm where the ECU cut kicks in
Old Jul 22, 2008 | 08:30 PM
LHD220Turbo's Avatar
LHD220Turbo
? confused mate, what car firstly, what spec?
so what you saying is it hold 10 psi until 4000rpm, then rises to 20psi until the rev limiter at 5500rpm?
Old Jul 22, 2008 | 08:49 PM
Kverna's Avatar
Kverna
Virgin-popper
Too weak actuator I'll guess
Old Jul 22, 2008 | 08:51 PM
LHD220Turbo
not sure as i wouldnt have thought a weak actuator would make 20psi, especially rising to 20psi as well; weak actuators normally result in a bit of boost then tailing off dramatically
Old Jul 22, 2008 | 08:52 PM
an1mal_69's Avatar
an1mal_69
its a 2.1, fresh build
T3/4 with a focus RS act' Ive not set the actuator yet as ive only just got a decent set of hoses on, kept poppin my others off, but id expect a weak actuator to leak boost not increase it..??
Im not worried about it, as i said ive not set it proper yet..jus thought it was a wierd thing to happen..
Old Jul 22, 2008 | 11:26 PM
Kverna's Avatar
Kverna
Virgin-popper
Sorry I'm in my own thoughts tonight. Never mind my post
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
