Poorly RS..Please help...
Old Jul 21, 2008 | 10:22 PM
macrs's Avatar
macrs
Angry Poorly RS..Please help...
Just wondering if anyone can shed some light for me...
Was out in the S2 tonight, gave it some beans (only up to 5000 RPM)..not too much thrashing in second gear.
Someting went 'pop', and the engine cut out just as I was shifting into third. At first I thought it was the ECU cutting the engine out, or it was terminal... Not so as everything seems fine, no knocks or bangs and it is a very healthy engine (or it was)..
Its getting a spark but appears to be getting no fuel?!?!? Fuel pump runs while cranking over and theres fuel to the metering head..relays and fuses seem ok..
Could it be that the metering head has waived the white flag and given up???
Thanks if you can help...
Mac26
Old Jul 21, 2008 | 10:24 PM
mk3cab's Avatar
mk3cab
boost hose maybe? mine does it all the time lol
andyorion's Avatar
andyorion
Sounds like you might have popped a boost hose? Have you checked to make sure they are all still securely fitted?
Old Jul 21, 2008 | 10:32 PM
macrs's Avatar
macrs
Yeah, checked them all lads...its turns over but wont fire up.
Thanks for the ideas though!!
Old Jul 22, 2008 | 09:11 AM
stephenbatey's Avatar
stephenbatey
Spring/clip under the flap on metering unit mate, had exactly same thing happen to me before. Try getting a mate to start it while you hold the flap on the metering unit down a little, should fire straight up. If i does its knackered, i bought new metering unit and mine been sound since. Hope this helps you out mate.
Old Jul 22, 2008 | 11:11 AM
macrs's Avatar
macrs
CheeRS for the help lads. Got it sorted now!!!!!!!!!!!!!!!
Re-checked the boost hoses this morning and the bottom hose from the turbo to the IC had poped off!!!! How much of a tit do I feel for not checking properly!
How relieved am I.....Thought i'd screwed it lastnight! Was kinda panicing like fek.
Thanks again lads and thanks to Passion Ford!
Old Jul 22, 2008 | 05:06 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
lol glad it was nothing serious
Old Jul 23, 2008 | 09:30 AM
macrs's Avatar
macrs
Cheers!!
Brickhouse
14
Oct 3, 2015 07:28 PM
jason_nike
Aug 31, 2015 10:15 PM
borboyous
Aug 22, 2015 11:17 AM
Dr. Ickxs
Aug 15, 2015 11:34 AM
bassboy
Aug 5, 2015 08:21 AM
