cossy problem
Old Jul 21, 2008 | 08:53 PM
fezzajsy's Avatar
fezzajsy
Default cossy problem
right just got the sappf for a drive n noticed the rev are on 500rpm on idle?Deffo not right.dont think all cylinders are running right
Any clues.thanx
Old Jul 21, 2008 | 10:19 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
possibly your idle control valve. mine did it for a while, took the valve out gave it a good clean and it sorted the prob out.
Old Jul 21, 2008 | 10:24 PM
Kverna's Avatar
Kverna
Virgin-popper
With the engine running, plug out the icv. If the revs don't change, it's broken. Try to clean it or replace
Old Jul 22, 2008 | 07:58 AM
rog's Avatar
rog
It doubt it will be the ISCV if it's not runing on all cylinders, more likely a plug or lead, what i normally do is, with the engine running and bonnet open, disconnect and reconnect the leads one by one till you hear no difference, that will tell you which cylinder isn't firing, and like i said will most likely be a plug or lead.
Old Jul 22, 2008 | 12:29 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
incorrect imo,
if the revs dont change when you unplugg the iscv, it just means the base idle is at the correct speed.
Old Jul 22, 2008 | 12:53 PM
rog's Avatar
rog
Better still, take it off, it's only 2 screws, clean it up and wire it upto a battery (i think i just used a square 9V one like you find in a smoke alarm), it should click as it's just a solenoid, i had to do this with mine as the car sat for almost 2 years and it was stuck, put some WD40 on it and it was ok after 10mins.
marky_g
Sep 12, 2015 04:26 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
Thanasis
Sep 7, 2015 07:33 PM
routemaster
Sep 7, 2015 05:27 PM
