cvh rev counter wiring
Old Jul 20, 2008 | 06:50 PM
10th_racer's Avatar
10th_racer
Default cvh rev counter wiring
i'v had this rev counter in an frst engined ka for a while now, but because its a 4 cylinder rev counter rather than 2 cylinder, i need to use both feed wires from the coilpack, if i just use the 1 then the rev counter only reads half what it should, but if i use the 2 wires then the rev counter reads right but its basically bridging the 2 wires and doesnt run right as if its firing on all 4 cylinders all the time.
i'v been told that there is some sort of diode you can get to stop it feeding back? is this right? if so what do i need?
any help much apprechiated.
Old Jul 20, 2008 | 09:11 PM
irsq4's Avatar
irsq4
You'll have to use Z-diode's. I saw similar thing on web once, try to google
Old Jul 20, 2008 | 09:19 PM
mk3matt's Avatar
mk3matt
i got told on here, you basicly need to put the diode 1n4004 in line on both wires, then put it onto one. aparently this works, however, it did not for me
if you do work it out PLEASE pm me! im on a man hunt for a 2 cylinder rev counter now to try and sort it!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
