2 stage boost
Old Jul 20, 2008 | 03:49 PM
markyrst's Avatar
markyrst
Default 2 stage boost
ive got a s2 erst and want to run 2 stage boost. i understand its just a matter of cutting into the earth connection on the amal valve and fitting a switch. im currentling 1 bar of boost all the time and would like to run about 0.5 -0.6 bar on low boost setting, just to see if it would work i disconnected the plug from the amal valve which you would imagine would be the same thing as switching it off, but the boost pressure still remains at 1 bar. can anyone help me??
Old Jul 20, 2008 | 03:50 PM
Stu @ M Developments's Avatar
PassionFords Creator
Sounds like your amal either isnt plumbed in or its broken pal.
Old Jul 20, 2008 | 09:06 PM
markyrst's Avatar
markyrst
is it possible my ecu doesnt control the amal valve any more as has a collins chip
Old Jul 20, 2008 | 10:59 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
does it click when u turn the key on??
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
Russ Payne
Sep 25, 2015 08:29 PM
