hydralic lifters help?
Old Jul 19, 2008 | 05:57 PM
smerth54's Avatar
smerth54
Question hydralic lifters help?
put some kent hydraulic lifters(followers) in my car today but i don't know what to set them to? as there wasn't a sheet telling me or anything any ideas?
Old Jul 19, 2008 | 07:52 PM
picky775's Avatar
picky775
Dont think your meant to set them if there hydraulic mate,think its solid lifters you need to adjust.
Old Jul 19, 2008 | 09:36 PM
Rick's Avatar
Rick
hydraulic.... u dont touch them. But, if you haven't put a new cam in at the same time, they will be scrap by now.
Old Jul 20, 2008 | 02:58 AM
smerth54's Avatar
smerth54
There not the hydraulic ones cos they've got to sorta nuts on top that need setting up any ideas?
Old Jul 20, 2008 | 09:28 AM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
i'd go for .008 inlet, .012 exhaust (0.2mm and 0.3mm)
Old Jul 20, 2008 | 10:07 AM
smerth54's Avatar
smerth54
ok then cheers mate
Old Jul 20, 2008 | 10:31 AM
Turbo Zetec
Engine Machinist
they're just standard-ish figures for most cars to be honest...
if you know what cam you have, you can look on kent cams website at their broschure and it'll give you the exact figures. if you haven't got a cam designed for solid lifters, you'll lose some lift.
Old Jul 20, 2008 | 10:52 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Is the cam meant to be used with solid lifters or was it originally used with hydrualic lifters?
it DOES matter!
Old Jul 20, 2008 | 11:57 AM
haz87's Avatar
haz87
And as Rick said, is it a new cam? or are you just bunging the lifters in?
Old Jul 21, 2008 | 01:11 AM
smerth54's Avatar
smerth54
its a fast road kent cam
Old Jul 21, 2008 | 07:23 AM
xr4x4rs's Avatar
xr4x4rs
i take it its for the fiesta?
and the things with nuts on are like a boat kinda shape if so these armt your lifters, lifters are the cylinders things that fit below it
but the haynes manual should tell you what setting to torque the nuts upto, but dont over tighten them as they have a tendencu to rip the stud and threads out the head
Old Jul 21, 2008 | 04:10 PM
smerth54's Avatar
smerth54
yea i know what the lifters are but there adjustable so hence asking?
Old Jul 23, 2008 | 05:47 PM
smerth54's Avatar
smerth54
so if the cam is a hydralic one i need hydralic lifters instead of the adjustable ones?
Old Jul 23, 2008 | 06:09 PM
xr4x4rs's Avatar
xr4x4rs
anychance of a pic as i havnt a clue what you mean now
only adjustable ones i know of are on hcs engines or teh sierra v6
Old Jul 23, 2008 | 06:11 PM
smerth54's Avatar
smerth54
not really there all in now
but basically the followers/lifter ive got have to different bolts on the top which you can adjust but the hydraulics don't so im guessing for a hydraulic cam shaft ill need hydraulic lifters yea?
Old Jul 23, 2008 | 06:24 PM
smerth54's Avatar
smerth54
did that make sense?
Old Jul 23, 2008 | 06:36 PM
xr4x4rs's Avatar
xr4x4rs
are yours like this
http://www.fastfords.org.uk/pics/newmanc5.jpg
Old Jul 23, 2008 | 06:45 PM
smerth54's Avatar
smerth54
these are the ones but i think these are wrong and i need the hydraulic ones
Old Jul 23, 2008 | 06:53 PM
xr4x4rs's Avatar
xr4x4rs
as far as i know there adjustable solid lifters
i think newman cams supply these in there kits
they need to be adjusted to to whatever they say in the instructions before fitment i think
but yes the other type are hydraulic and are different
with these ones you have the benefits are more for higher revving engines like 8k
Old Jul 24, 2008 | 12:49 AM
smerth54's Avatar
smerth54
oh rite i see, well in the book that came with the cam it doesn't give u any measurements as tho i should have the other type of ones
Old Jul 24, 2008 | 07:28 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
AFPMSL at the sudden influx of people lately that think you can just put Solid Followers with a normal cam intended for Hydraulics.
Old Jul 24, 2008 | 11:31 PM
smerth54's Avatar
smerth54
see i wasn't sure ad when i ordered my kent cam thats the only kent followers that were on there so i assumed they were the right ones, obviously there not so got a set of hydraulic followers on there way
Old Jul 24, 2008 | 11:47 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Im one of them,although nothing suddenly or lately in my case, and I know loads of people who have been doing so for years and never had a problem, even on 10K+ miles on trackday engines, with no visible cam wear, in fact ive got hydraulic profile N/A cams in my turbo nova on solid lifters too!
Im well aware that you lose a small amount of lift when you do so, and im also aware that the ramp doesnt have the initial few thou gentley dialled in to increase cam life by lesening the impact at the beginning of the lift like many (but not all anyway!) solid cam profiles do, but bottom line is, it DOES work just fine in a lot of instances.
RUBY123
Oct 22, 2023 12:04 PM
nikh667
Jul 6, 2023 06:08 PM
Roosie
Aug 13, 2015 07:40 PM
pee vee
Mar 21, 2005 07:43 PM
Christian and Beccy
29
Jan 18, 2005 01:52 PM
