help need to now what pipes go to where on an amal valve
hi there ppl i need to now where the pipes go on the amal valve anone have any pics thanks
PassionFords Creator
and the electrical connections go....?
mine has sat in my shed since the twat that did my engine conversion decided it wasnt needed. i used to have a 7psi and 15psi switch on my dash in my last project
now its getting complicated
ecu pin 16 in a l6 ecu? does it matter which ones which as they are unmarked and in a T formation ? and im probably asking the obvious but would the dash switch be spliced inline on the pin 16 wire?
